A Closer Look at MOMDPs, 2010 22nd IEEE International Conference on Tools with Artificial Intelligence, 2010. ,
DOI : 10.1109/ICTAI.2010.101
Dynamic Programming, 1957. ,
An e-optimal grid-based algorithm for partially obserable Markov decision processes, Proc. of the 19th Int. Conf. on Machine Learning (ICML-02), 2002. ,
Computing optimal policies for partially observable decision processes using compact representations, Proc. of the Nat. Conf. on Artificial Intelligence, 1996. ,
A heuristic variable grid solution method for POMDPs, Proc. of the Nat. Conf. on Artificial Intelligence, 1997. ,
When to stop managing or surveying cryptic threatened species, Proceedings of the National Academy of Sciences, vol.105, issue.37, pp.13936-13940, 2008. ,
DOI : 10.1073/pnas.0805265105
Uncertainty and adaptive management for biodiversity conservation, Biological Conservation, vol.144, issue.4 ,
DOI : 10.1016/j.biocon.2010.11.022
Computationally Feasible Bounds for Partially Observed Markov Decision Processes, Operations Research, vol.39, issue.1, pp.162-175, 1991. ,
DOI : 10.1287/opre.39.1.162
Getting the biggest bang for our conservation buck, Trends in Ecology & Evolution, vol.24, issue.4, pp.175-177, 2009. ,
DOI : 10.1016/j.tree.2008.12.002
On the undecidability of probabilistic planning and related stochastic optimization problems, Artificial Intelligence, vol.147, issue.1-2, pp.5-34, 2003. ,
DOI : 10.1016/S0004-3702(02)00378-8
Planning under Uncertainty for Robotic Tasks with Mixed Observability, The International Journal of Robotics Research, vol.21, issue.3, pp.1053-1068, 2010. ,
DOI : 10.1177/0278364910369861
The Complexity of Markov Decision Processes, Mathematics of Operations Research, vol.12, issue.3, pp.441-450, 1987. ,
DOI : 10.1287/moor.12.3.441
Point-based value iteration : An anytime algorithm for POMDPs, Proc. of the Int. Joint Conf. on Artificial Intelligence, 2003. ,
Exploiting Structure to Efficiently Solve Large Scale Partially Observable Markov Decision Processes, 2005. ,
An analytic solution to discrete Bayesian reinforcement learning, Proceedings of the 23rd international conference on Machine learning , ICML '06, 2006. ,
DOI : 10.1145/1143844.1143932
The Optimal Control of Partially Observable Markov Decision Processes, 1971. ,
Perseus : Randomized point-based value iteration for POMDPs, Journal of Artificial Intelligence Research, vol.24, pp.195-220, 2005. ,
Ecological Optimization and Adaptive Management, Annual Review of Ecology and Systematics, vol.9, issue.1, pp.157-188, 1978. ,
DOI : 10.1146/annurev.es.09.110178.001105
Markov decision processes in natural resources management: Observability and uncertainty, Ecological Modelling, vol.220, issue.6, pp.830-840, 2009. ,
DOI : 10.1016/j.ecolmodel.2008.12.023
An improved grid-based approximation algorithm for POMDPs, Proc. of the 17th Int. Joint Conf. on Artificial Intelligence, 2001. ,
