Application of global optimization to the design of pipe networks, Proc. 3rd International Conference on Hydroinformatics, pp.989-996, 1998. ,
Optimal structure of gas transmission trunklines, Optimization and Engineering, vol.6, issue.2, pp.175-198, 2011. ,
DOI : 10.1007/s11081-009-9094-2
Optimization of capacity expansion planning for gas transportation networks, European Journal of Operational Research, vol.197, issue.3, pp.1019-1027, 2009. ,
DOI : 10.1016/j.ejor.2007.12.045
Design and Operations of Gas Transmission Networks, Operations Research, vol.60, issue.1, 2011. ,
DOI : 10.1287/opre.1110.1001
The gas transmission problem when the merchant and the distribution functions are disconnected, 2007. ,
Optimal dimensioning of pipe networks: the new situation when the distribution and the transportation functions are disconnected, 2008. ,
Solving gas transmission problems by taking compressors into account, 2008. ,
Improving Interval Analysis Bounds by Translations, Journal of Global Optimization, vol.29, issue.2, pp.157-172, 2004. ,
DOI : 10.1023/B:JOGO.0000042114.11969.bb
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.894
Pipeline optimization: dynamic programming after 30 years, Proc. 30th PSIG Annual Meeting, 1998. ,
The simplex algorithm extended to piecewise linearly constrained problems ii: An application to the gas transmission problem, Technical Report CORE, 1991. ,
Optimization of pipe networks, Mathematical Programming, vol.107, issue.2, pp.45-58, 1988. ,
DOI : 10.1007/BF01582879
AN OVERVIEW OF GLOBAL OPTIMIZATION USING INTERVAL ANALYSIS, of Monographs and Textbooks in Pure and Applied Mathematics, 2004. ,
DOI : 10.1016/B978-0-12-505630-4.50021-3
Comparison Between Baumann and Admissible Simplex Forms in Interval Analysis, Journal of Global Optimization, vol.30, issue.4, pp.215-228, 2007. ,
DOI : 10.1007/s10898-006-9045-9
Global optimization, 1993. ,
Optimized design of a gas-distribution pipeline network, Applied Energy, vol.48, issue.3, pp.217-224, 1994. ,
DOI : 10.1016/0306-2619(94)90011-6
??tude de r??seaux de transport et de distribution de fluide, RAIRO - Operations Research, vol.11, issue.2, pp.243-248, 1977. ,
DOI : 10.1051/ro/1977110202431
Méthodes d'Optimisation Globale basées sur l'Analyse d'Intervalle pour la Résolution desProbì emes avec Contraintes, 1997. ,
Extensions of affine arithmetic: application to unconstrained global optimization, J.UCS, vol.8, issue.11, pp.992-1015, 2002. ,
Deterministic global optimization using interval constraint propagation techniques, RAIRO - Operations Research, vol.38, issue.4, pp.277-293, 2004. ,
DOI : 10.1051/ro:2004026
Procédé d'optimisation automatique d'un réseau de transport de gaz naturel, 2007. ,
Method for the automatic optimization of a natural gas transport network, 2009. ,
The COMOGA method: Constrained optimisation by multi-objective genetic algorithms, Control and Cybernetics, vol.26, 1997. ,
Application of genetic algorithms - Determination of the optimal pipe diameters, Water SA, vol.28, issue.2, pp.217-223, 2002. ,
DOI : 10.4314/wsa.v28i2.4888
The gas transmission problem solved by an extension of the simplex algorithm, Management Sciences, vol.46, issue.11, pp.1454-1465, 2000. ,
A Bilevel Programming Method for Pipe Network Optimization, SIAM Journal on Optimization, vol.6, issue.3, pp.838-857, 1996. ,
DOI : 10.1137/S1052623493260696
