Journal articles
Interaction of cellular and network mechanisms for efficient pheromone coding in moths
Abstract : Sensory systems, both in the living and in machines, have to be optimized with respect to their environmental conditions. The pheromone subsystem of the olfactory system of moths is a particularly well-defined example in which rapid variations of odor content in turbulent plumes require fast, concentration-invariant neural representations. It is not clear how cellular and network mechanisms in the moth antennal lobe contribute to coding efficiency. Using computational modeling, we show that intrinsic potassium currents (IA and ISK) in projection neurons may combine with extrinsic inhibition from local interneurons to implement a dual latency code for both pheromone identity and intensity. The mean latency reflects stimulus intensity, whereas latency differences carry concentration-invariant information about stimulus identity. In accordance with physiological results, the projection neurons exhibit a multiphasic response of inhibition-excitation-inhibition. Together with synaptic inhibition, intrinsic currents IA and ISK account for the first and second inhibitory phases and contribute to a rapid encoding of pheromone information. The first inhibition plays the role of a reset to limit variability in the time to first spike. The second inhibition prevents responses of excessive duration to allow tracking of intermittent stimuli.
Document type :
Journal articles
Complete list of metadata
Cited literature [55 references]  Display  Hide  Download
https://hal.inria.fr/hal-00643171
Contributor : Dominique Martinez Connect in order to contact the contributor
Submitted on : Friday, May 29, 2020 - 1:57:34 PM
Last modification on : Friday, August 5, 2022 - 2:38:10 PM
File
2011_Belmabrouk_Proceedings of...
Publisher files allowed on an open archive
Identifiers
Citation
Hana Belmabrouk, Thomas Nowotny, Jean-Pierre Rospars, Dominique Martinez. Interaction of cellular and network mechanisms for efficient pheromone coding in moths. Proceedings of the National Academy of Sciences of the United States of America, National Academy of Sciences, 2011, 108 (49), pp.19790-19795. ⟨10.1073/pnas.1112367108⟩. ⟨hal-00643171⟩
Share
Metrics
Record views
313
Files downloads
55
