Composition, quantification and periodicity of sex pheromone gland volatiles from individual Heliothis virescens females, J Chem Ecol, vol.8, pp.1043-1055, 1982. ,
Composition, quantification, and periodicity of sex pheromone volatiles from individual Heliothis zea females, J Insect Physiol, vol.30, pp.943-945, 1984. ,
Sex pheromones and their potential role in the evolution of reproductive isolation in small ermine moths (Yponomeutidae), Chemoecology, vol.2, pp.20-28, 1991. ,
Sex pheromone blend discrimination by male moths from E and Z strains of European corn borer, J Chem Ecol, vol.13, pp.143-151, 1987. ,
Sex pheromone blend discrimination in two races and hybrids of the European corn borer moth, Ostrinia nubilalis, Physiol Entomol, vol.22, pp.212-223, 1997. ,
Effects of varying sex pheromone component ratios on the zigzagging flight movements of the oriental fruit moth, Grapholita molesta, J Insect Behav, vol.1, pp.357-371, 1988. ,
Filamentous nature of pheromone plumes protects integrity of signal from background chemical noise in cabbage looper moth, Trichoplusia ni, J Chem Ecol, vol.18, pp.299-307, 1992. ,
On the structure of instantaneous plumes in the atmosphere, J Hazard Mater, vol.7, pp.87-112, 1983. ,
Physical processes and real-time chemical measurement of the insect olfactory environment, J Chem Ecol, vol.34, pp.837-853, 2008. ,
Encoding of olfactory information with oscillating neural assemblies, Science, vol.265, pp.1872-1875, 1994. ,
Temporal representations of odors in an olfactory network, J Neurosci, vol.16, pp.3837-3847, 1996. ,
A systems perspective on early olfactory coding, Science, vol.286, pp.723-728, 1999. ,
Odour-plume dynamics influence the brain's olfactory code, Nature, vol.410, pp.466-470, 2001. ,
Adaptation of antennal neurons in moths is associated with cessation of pheromone-mediated upwind flight, Proc Natl Acad Sci, vol.85, pp.9826-9830, 1988. ,
Olfactory modulation of flight in Drosophila is sensitive, selective and rapid, J Exp Biol, vol.213, pp.3625-3635, 2010. ,
Identification of a pheromone blend attractive to Manduca sexta (L.) males in a wind tunnel, Arch Insect Biochem Physiol, vol.10, pp.255-271, 1989. ,
Pheromone receptor cells in the male moth Manduca sexta, Arch Insect Biochem Physiol, vol.10, pp.273-279, 1989. ,
Male-specific, sex pheromone-selective projection neurons in the antennal lobes of the moth Manduca sexta, J Comp Physiol A Neuroethol Sens Neural Behav Physiol, vol.160, pp.553-569, 1987. ,
Projections to higher olfactory centers from subdivisions of the antennal lobe macroglomerular complex of the male silkmoth, Chem Senses, vol.28, pp.113-130, 2003. ,
Olfactory information processing in moths. The Neurobiology of Olfaction, pp.71-112, 2010. ,
Local inhibition modulates odor-evoked synchronization of glomerulus-specific output neurons, Nat Neurosci, vol.5, pp.557-565, 2002. ,
GABA-mediated synaptic inhibition of projection neurons in the antennal lobes of the sphinx moth, Manduca sexta, J Comp Physiol A Neuroethol Sens Neural Behav Physiol, vol.161, pp.23-32, 1987. ,
Subunit composition determines picrotoxin and bicuculline sensitivity of Drosophila gammaaminobutyric acid receptors, Mol Pharmacol, vol.48, pp.835-840, 1995. ,
Multitasking in the olfactory system: Context-dependent responses to odors reveal dual GABA-regulated coding mechanisms in single olfactory projection neurons, J Neurosci, vol.18, pp.5999-6008, 1998. ,
Bicuculline block of small-conductance calcium-activated potassium channels, Pflugers Arch, vol.438, pp.314-321, 1999. ,
Effect of bicuculline on thalamic activity: A direct blockade of IAHP in reticularis neurons, J Neurophysiol, vol.79, pp.2911-2918, 1998. ,
Modulatory effects of 5-hydroxytryptamine on voltage-activated currents in cultured antennal lobe neurones of the sphinx moth Manduca sexta, J Exp Biol, vol.198, pp.613-627, 1995. ,
Developmental changes in the density of ionic currents in antennal-lobe neurons of the sphinx moth, Manduca sexta, J Neurophysiol, vol.87, pp.2664-2675, 2002. ,
Olfactory mechanisms in the moth Manduca sexta: Response characteristics and morphology of central neurons in the antennal lobes, Proc R Soc Lond B Biol Sci, vol.213, pp.249-277, 1981. ,
Contrast enhancement of stimulus intermittency in a primary olfactory network and its behavioral significance, J Biol, vol.8, p.21, 2009. ,
Rate coding versus temporal order coding: What the retinal ganglion cells tell the visual cortex, Neural Comput, vol.13, pp.1255-1283, 2001. ,
Latency: Another potential code for feature binding in striate cortex, J Neurophysiol, vol.76, pp.1356-1360, 1996. ,
Rapid neural coding in the retina with relative spike latencies, Science, vol.319, pp.1108-1111, 2008. ,
First spikes in ensembles of human tactile afferents code complex spatial fingertip events, Nat Neurosci, vol.7, pp.170-177, 2004. ,
Pattern recognition computation using action potential timing for stimulus representation, Nature, vol.376, pp.33-36, 1995. ,
Theta oscillation coupled spike latencies yield computational vigour in a mammalian sensory system, J Physiol, vol.546, pp.363-374, 2003. ,
Olfactory coding with patterns of response latencies, Neuron, vol.67, pp.872-884, 2010. ,
Relational representation in the olfactory system, Proc Natl Acad Sci, vol.104, pp.1953-1958, 2007. ,
Competition-based model of pheromone component ratio detection in the moth, PLoS One, vol.6, p.16308, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00579546
How neurons may compute: The case of insect sexual pheromone discrimination, J Comput Neurosci, vol.1, pp.231-238, 1994. ,
URL : https://hal.archives-ouvertes.fr/hal-02704036
Encoding of odour blends in the moth antennal lobe, 2007. ,
Spike latency coding in a biologically inspired microelectronic nose, IEEE Trans Biomed Circuits Syst, vol.5, pp.160-168, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00543031
Coordination of central odor representations through transient, non-oscillatory synchronization of glomerular output neurons, Proc Natl Acad Sci, vol.100, pp.11076-11081, 2003. ,
Frequency transitions in odorevoked neural oscillations, Neuron, vol.64, pp.692-706, 2009. ,
Synchronization in networks of excitatory and inhibitory neurons with sparse, random connectivity, Neural Comput, vol.15, pp.509-538, 2003. ,
Chemical and electrical synapses perform complementary roles in the synchronization of interneuronal networks, Proc Natl Acad Sci, vol.101, pp.15482-15487, 2004. ,
Oscillatory synchronization requires precise and balanced feedback inhibition in a model of the insect antennal lobe, Neural Comput, vol.17, pp.2548-2570, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000646
A model of stimulus-specific neural assemblies in the insect antennal lobe, PLoS Comput Biol, vol.4, p.1000139, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00336099
Rapid odor processing in the honeybee antennal lobe network, Front Comput Neurosci, vol.2, p.9, 2009. ,
Computational diversity in a formal model of the insect olfactory macroglomerulus, Neural Comput, vol.5, pp.228-241, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-02705150
Oscillations and slow patterning in the antennal lobe, J Comput Neurosci, vol.20, pp.85-96, 2006. ,
Spike frequency adaptation mediates looming stimulus selectivity in a collision-detecting neuron, Nat Neurosci, vol.12, pp.318-326, 2009. ,
Structure and function of the deutocerebrum in insects, Annu Rev Entomol, vol.34, pp.477-501, 1989. ,
Using heterogeneity to predict inhibitory network model characteristics, J Neurophysiol, vol.93, pp.1898-1907, 2005. ,
A tutorial on support vector machines for pattern recognition, Data Mining and Knowledge Discovery, vol.2, pp.121-167, 1998. ,
