Journal articles
Lyusternik-Graves theorem and fixed points
Asen L. Dontchev Hélène Frankowska 1
1 C&O - Equipe combinatoire et optimisation
IMJ-PRG - Institut de Mathématiques de Jussieu - Paris Rive Gauche
Abstract : Abstract: For set-valued mappings $ F$ and $ \Psi$ acting in metric spaces, we present local and global versions of the following general paradigm which has roots in the Lyusternik-Graves theorem and the contraction principle: if $ F$ is metrically regular with constant $ \kappa$ and $ \Psi$ is Aubin (Lipschitz) continuous with constant $ \mu$ such that $ \kappa\mu <1$, then the distance from $ x$ to the set of fixed points of $ F^{-1}\Psi$ is bounded by $ \kappa/(1-\kappa \mu)$ times the infimum distance between $ \Psi(x)$ and $ F(x)$. From this result we derive known Lyusternik-Graves theorems, a recent theorem by Arutyunov, as well as some fixed point theorems.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00643231
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Monday, November 21, 2011 - 2:38:06 PM
Last modification on : Saturday, April 30, 2022 - 3:36:08 AM
Links full text
Identifiers
Citation
Asen L. Dontchev, Hélène Frankowska. Lyusternik-Graves theorem and fixed points. Proceedings of the American Mathematical Society, American Mathematical Society, 2011, 139, pp.521-534. ⟨10.1090/S0002-9939-2010-10490-2⟩. ⟨hal-00643231⟩
Share
Metrics
Record views
105
