Simulating individual-based models of bacterial chemotaxis with asymptotic variance reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2013
We discuss variance reduced simulations for an individual-based model of chemotaxis of bacteria with internal dynamics. The variance reduction is achieved via a coupling of this model with a simpler process in which the internal dynamics has been replaced by a direct gradient sensing of the chemoattractants concentrations. In the companion paper \cite{limits}, we have rigorously shown, using a pathwise probabilistic technique, that both processes converge towards the same advection-diffusion process in the diffusive asymptotics. In this work, a direct coupling is achieved between paths of individual bacteria simulated by both models, by using the same sets of random numbers in both simulations. This coupling is used to construct a hybrid scheme with reduced variance. We first compute a deterministic solution of the kinetic density description of the direct gradient sensing model; the deviations due to the presence of internal dynamics are then evaluated via the coupled individual-based simulations. We show that the resulting variance reduction is \emph{asymptotic}, in the sense that, in the diffusive asymptotics, the difference between the two processes has a variance which vanishes according to the small parameter.
variance.pdf (381.71 Ko) Télécharger le fichier
hal-00643324 , version 1 (22-11-2011)
Paternité - Pas d'utilisation commerciale - Pas de modification
Mathias Rousset, Giovanni Samaey. Simulating individual-based models of bacterial chemotaxis with asymptotic variance reduction. Mathematical Models and Methods in Applied Sciences, 2013, 23 (12), pp.2155 - 2191. ⟨10.1142/S0218202513500292⟩. ⟨hal-00643324⟩
275 Consultations
117 Téléchargements
