New interface
Other publications
From Linear Temporal Logic Properties to Rewrite Propositions
Pierre-Cyrille Heam 1 Vincent Hugot 1 Olga Kouchnarenko 1
1 CASSIS - Combination of approaches to the security of infinite states systems
FEMTO-ST - Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (UMR 6174), Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : In the regular model-checking framework, reachability analysis can be guided by temporal logic properties, for instance to achieve the counter example guided abstraction refinement (CEGAR) objectives. A way to perform this analysis is to translate a temporal logic formula expressed on maximal rewriting words into a ''rewrite proposition'' -- a propositional formula whose atoms are language comparisons, and then to generate semi-decision procedures based on (approximations of) the rewrite proposition. This approach has recently been studied using a non-automatic translation method. The extent to which such a translation can be systematised needs to be investigated, as well as the applicability of approximated methods wherever no exact translation can be effected. This paper presents contributions to that effect: 1) we investigate suitable semantics for LTL on maximal rewriting words and their influence on the feasibility of a translation, and 2) we propose a general scheme providing exact results on a fragment of LTL corresponding mainly to safety formulæ, and approximations on a larger fragment.
Document type :
Other publications
Complete list of metadata
https://hal.inria.fr/hal-00643416
Contributor : Olga Kouchnarenko Connect in order to contact the contributor
Submitted on : Monday, November 21, 2011 - 6:34:38 PM
Last modification on : Friday, January 21, 2022 - 3:09:37 AM
Identifiers
  • HAL Id : hal-00643416, version 1
Citation
Pierre-Cyrille Heam, Vincent Hugot, Olga Kouchnarenko. From Linear Temporal Logic Properties to Rewrite Propositions. 2011. ⟨hal-00643416⟩
Share
Metrics
Record views
188
