Heat can cool near-critical fluids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E : Statistical, Nonlinear, and Soft Matter Physics Année : 2011
We report experiments with very compressible fluids near the liquid-gas critical point. These experiments are performed (i) under microgravity in low Earth orbit by using SF6 at liquidlike density and (ii) under Earth's gravity with CO2 at gaslike density. The sample fluid is filled in an interferometer cell with its walls maintained at constant temperature. In situ thermistors measure the local fluid temperature. One of the thermistors is also used as a heat source to generate heat pulses. With no gravity-induced fluid convection, the evolution of fluid temperature is governed by the balance of heat flux between the thermal boundary layer of the heat source, which compresses the bulk fluid, and the thermal boundary layer at the wall, which expands it. When heat pulses are applied to the fluid under weak or Earth's gravity, a long thermal transient is observed at the end of the heat pulse where the bulk fluid temperature reaches significantly below the initial temperature. This unconventional cooling originates from the fast decompression of the fluid, which is induced by the rapid convectively disappearing hot boundary layer at the heat source, and the persistence of an anomalously thin cold boundary layer convectively induced at the cell wall. This striking phenomenon is observed in a large range of temperature, density, and various thermodynamic conditions. This anomalous cooling effect persists for an appreciable period of time corresponding to the diffusive destruction of the cold boundary layer. We found that the effect is also more pronounced when the free fall acceleration is large. We have analyzed the result by using a simple one-dimensional model with ad hoc convective heat losses.
2011-158.pdf (742.07 Ko) Télécharger le fichier
hal-00643606 , version 1 (15-06-2021)
Daniel Beysens, Thomas Fröhlich, Yves Garrabos. Heat can cool near-critical fluids. Physical Review E : Statistical, Nonlinear, and Soft Matter Physics, 2011, 84 (5), pp.051201. ⟨10.1103/PhysRevE.84.051201⟩. ⟨hal-00643606⟩
259 Consultations
50 Téléchargements
