A constructive version of Birkhoff's ergodic theorem for Martin-Lof random points
Abstract : A theorem of Kucera states that given a Martin-Löf random infinite binary sequence {\omega} and an effectively open set A of measure less than 1, some tail of {\omega} is not in A. We first prove several results in the same spirit and generalize them via an effective version of a weak form of Birkhoff's ergodic theorem. We then use this result to get a stronger form of it, namely a very general effective version of Birkhoff's ergodic theorem, which improves all the results previously obtained in this direction, in particular those of V'Yugin, Nandakumar and Hoyrup, Rojas.
Liste complète des métadonnées
Littérature citée [10 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-00643629
Contributeur : Mathieu Hoyrup <>
Soumis le : mardi 22 novembre 2011 - 14:20:24
Dernière modification le : vendredi 4 janvier 2019 - 17:32:56
Document(s) archivé(s) le : vendredi 16 novembre 2012 - 11:45:37
Fichier
ergodic-edited.pdf
Fichiers produits par l'(les) auteur(s)
Citation
Laurent Bienvenu, Adam Day, Mathieu Hoyrup, Ilya Mezhirov, Alexander Shen. A constructive version of Birkhoff's ergodic theorem for Martin-Lof random points. Information and Computation, Elsevier, 2012, 210, pp.021-030. 〈http://www.sciencedirect.com/science/article/pii/S0890540111001465〉. 〈10.1016/j.ic.2011.10.006〉. 〈hal-00643629〉
Métriques
Consultations de la notice
756
Téléchargements de fichiers
193
