New interface
Book sections
Proximal Splitting Methods in Signal Processing
Abstract : The proximity operator of a convex function is a natural extension of the notion of a projection operator onto a convex set. This tool, which plays a central role in the analysis and the numerical solution of convex optimization problems, has recently been introduced in the arena of signal processing, where it has become increasingly important. In this paper, we review the basic properties of proximity operators which are relevant to signal processing and present optimization methods based on these operators. These proximal splitting methods are shown to capture and extend several well-known algorithms in a unifying framework. Applications of proximal methods in signal recovery and synthesis are discussed.
keyword : sadco
Complete list of metadata
https://hal.inria.fr/hal-00643807
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Tuesday, November 22, 2011 - 6:45:37 PM
Last modification on : Saturday, January 15, 2022 - 3:56:36 AM
Links full text
Identifiers
Citation
Patrick Louis Combettes, Jean-Christophe Pesquet. Proximal Splitting Methods in Signal Processing. Bauschke, H.H.; Burachik, R.S.; Combettes, P.L.; Elser, V.; Luke, D.R.; Wolkowicz, H. (Eds.). Fixed-Point Algorithms for Inverse Problems in Science and Engineering, Springer, pp.185-212, 2011, 978-1-4419-9568-1. ⟨10.1007/978-1-4419-9569-8⟩. ⟨hal-00643807⟩
Share
Metrics
Record views
1904
