Numerical methods for a reliable prediction of long water-wave phenomena : uncertainty quantification for tsunami runup - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Aim of this study is to present robust numerical methods for shallow water equations permitting to correctly predict long water-wave phenomena. A semi-intrusive and polynomial-chaos based method are coupled with a residual based distribution scheme by considering several sources of uncertainties in the simulation of a long wave runup on a conical island. Stochastic results are assessed by comparing with Monte Carlo results. Numerical solutions are compared with experimental data by displaying a great sensitivity from physical and modelling uncertainties.
RR-7809.pdf (569.24 Ko) Télécharger le fichier
hal-00643878 , version 1 (23-11-2011)
  • HAL Id : hal-00643878 , version 1
Mario Ricchiuto, Pietro Marco Congedo, Gianluca Geraci, Remi Abgrall. Numerical methods for a reliable prediction of long water-wave phenomena : uncertainty quantification for tsunami runup. [Research Report] RR-7809, INRIA. 2011. ⟨hal-00643878⟩
441 Consultations
118 Téléchargements
