Arc-flags in dynamic graphs In 9th Workshop on Algorithmic Approaches for Transportation Modeling, Optimization, graph n. of regions space AF (B) space AF and RS (B) ratio ,
Dynamic Multi-level Overlay Graphs for Shortest Paths, Mathematics in Computer Science, vol.1, issue.4, pp.709-736, 2008. ,
DOI : 10.1007/s11786-007-0023-5
Chapter 9. Case Studies, Case Studies, pp.389-445, 2010. ,
DOI : 10.1007/978-3-642-14866-8_9
Engineering Route Planning Algorithms, Algorithmics of Large and Complex Networks, pp.117-139, 2009. ,
DOI : 10.1007/978-3-540-39658-1_69
Landmark-Based Routing in Dynamic Graphs, 6th Workshop on Exp. Alg. (WEA'07), pp.52-65, 2007. ,
DOI : 10.1007/978-3-540-72845-0_5
A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271, 1959. ,
DOI : 10.1007/BF01386390
Fully Dynamic Algorithms for Maintaining Shortest Paths Trees, Journal of Algorithms, vol.34, issue.2, pp.251-281, 2000. ,
DOI : 10.1006/jagm.1999.1048
Computing the Shortest Path: A* Search Meets Graph Theory, 16th Annual ACM?SIAM Symposium on Discrete Algorithms (SODA'05), pp.156-165, 2005. ,
Fast Point-to-Point Shortest Path Computations with Arc-Flags, Shortest Path Computations: Ninth DIMACS Challenge, 2009. ,
METIS -A Family of Multilevel Partitioning Algorithms, 2007. ,
An extremely fast, exact algorithm for finding shortest paths. Static Networks with Geographical Background, pp.219-230, 2004. ,
Partitioning graphs to speedup Dijkstra's algorithm, Journal of Experimental Algorithmics, vol.11, issue.2, 2006. ,
DOI : 10.1145/1187436.1216585
Engineering Highway Hierarchies, 14th European Symp. on Alg. (ESA'06), pp.804-816, 2006. ,
Dynamic Highway-Node Routing, 6th Workshop on Exp. Alg. (WEA'07), pp.66-79, 2007. ,
Using Multi-level Graphs for Timetable Information in Railway Systems, 4th Workshop on Alg. Eng. and Experiments (ALENEX'02), volume 2409 of LNCS, pp.43-59, 2002. ,
DOI : 10.1007/3-540-45643-0_4
Geometric Speed-Up Techniques for Finding Shortest Paths in Large Sparse Graphs, 11th European Symp. on Alg. (ESA'03), pp.776-787, 2003. ,
Geometric containers for efficient shortest-path computation, Journal of Experimental Algorithmics, vol.10, pp.1-3, 2005. ,
DOI : 10.1145/1064546.1103378
