Network Congestion Control with Markovian Multipath Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we consider an integrated model for TCP/IP protocols with multipath routing. The model combines a Network Utility Maximization for rate control based on end-to-end queuing delays, with a Markovian Traffic Equilibrium for routing based on total expected delays. We prove the existence of a unique equilibrium state which is characterized as the solution of an unconstrained strictly convex program. A distributed algorithm for solving this optimization problem is proposed, with a brief discussion of how it can be implemented by adapting the current Internet protocols.
24-PID2128819.pdf (564.55 Ko) Télécharger le fichier
hal-00644098 , version 1 (23-11-2011)
  • HAL Id : hal-00644098 , version 1
Roberto Cominetti, Cristobal Guzman. Network Congestion Control with Markovian Multipath Routing. NetGCOOP 2011 : International conference on NETwork Games, COntrol and OPtimization, Telecom SudParis et Université Paris Descartes, Oct 2011, Paris, France. ⟨hal-00644098⟩
Collections
NETGCOOP2011
41 Consultations
188 Téléchargements
