A Distributed Algorithm for Random Convex Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study a distributed approach for solving random convex programs (RCP) for the case in which problem constraints are distributed among nodes in a processor network. We devise a distributed algorithm that allows network nodes to reach consensus on problem solution by exchanging a local set of constraints at each iteration. We prove that the algorithm assures finite-time convergence to problem solution and we provide explicit bounds on the maximum number of constraints to be exchanged among nodes at each communication round. Numerical experiments confirm the theoretical derivation and show that a parallel implementation of the proposed approach speeds-up the solution of the RCP with respect to centralized computation.
13-CR-paper.pdf (141.89 Ko) Télécharger le fichier
hal-00644380 , version 1 (24-11-2011)
  • HAL Id : hal-00644380 , version 1
Luca Carlone, Vaibhav Srivastava, Francesco Bullo, Giuseppe C. Calafiore. A Distributed Algorithm for Random Convex Programming. NetGCOOP 2011 : International conference on NETwork Games, COntrol and OPtimization, Telecom SudParis et Université Paris Descartes, Oct 2011, Paris, France. ⟨hal-00644380⟩
Collections
NETGCOOP2011
49 Consultations
95 Téléchargements
