Algebraic topology: a first course, 1976. ,
Homology computation on cellular structures in image context, in: CTIC, Austria, pp.19-28, 2009. ,
Constructive Mayer-Vietoris algorithm: computing the homology of unions of simplicial complexes, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00542717
Measuring and computing natural generators for homology groups, Computational Geometry, vol.43, issue.2, pp.169-181, 2010. ,
DOI : 10.1016/j.comgeo.2009.06.004
URL : http://doi.org/10.1016/j.comgeo.2009.06.004
Vines and vineyards by updating persistence in linear time, Proceedings of the twenty-second annual symposium on Computational geometry , SCG '06, pp.119-126, 2006. ,
DOI : 10.1145/1137856.1137877
Computing Homology for Surfaces with Generalized Maps: Application to 3D Images, pp.235-244, 2006. ,
DOI : 10.1007/11919629_25
URL : https://hal.archives-ouvertes.fr/hal-00366105
A Dimension-Independent Data Structure for Simplicial Complexes, pp.403-420, 2010. ,
DOI : 10.1007/978-3-642-15414-0_24
Decomposing non-manifold objects in arbitrary dimensions, Graphical Models, vol.65, issue.1-3, pp.2-22, 2003. ,
DOI : 10.1016/S1524-0703(03)00006-7
An incremental algorithm for Betti numbers of simplicial complexes, Proceedings of the ninth annual symposium on Computational geometry , SCG '93, pp.232-239, 1993. ,
DOI : 10.1145/160985.161140
Computing homology groups of simplicial complexes in R3, Proc. 28th ACM Symp. Comp. Theory, 1996. ,
DOI : 10.1145/274787.274810
Computing geometry-aware handle and tunnel loops in 3d models, ACM Transactions on Graphics, vol.27, issue.45, 2008. ,
Approximating loops in a shortest homology basis from point data, Proceedings of the 2010 annual symposium on Computational geometry, SoCG '10, pp.166-175, 2010. ,
DOI : 10.1145/1810959.1810989
The kenzo program, 2008. ,
Computing Simplicial Homology Based on Efficient Smith Normal Form Algorithms, Alg., Geom., and Soft. Syst, pp.177-207, 2003. ,
DOI : 10.1007/978-3-662-05148-1_10
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.7.5885
Computational topology, an introduction, AMS, 2010. ,
Topological Persistence and Simplification, Discrete & Computational Geometry, vol.28, issue.4, pp.511-533, 2002. ,
DOI : 10.1007/s00454-002-2885-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.8802
Recognition of Occluded Shapes Using Size Functions, pp.642-651, 2009. ,
DOI : 10.1109/99.641604
Morse Theory for Cell Complexes, Advances in Mathematics, vol.134, issue.1, pp.90-145, 1998. ,
DOI : 10.1006/aima.1997.1650
Non-manifold Meshes Repository, 2009. ,
Coverage and hole-detection in sensor networks via homology, IPSN 2005. Fourth International Symposium on Information Processing in Sensor Networks, 2005., 2005. ,
DOI : 10.1109/IPSN.2005.1440933
Probabilistic computation of the Smith normal form of a sparse integer matrix, Lecture Notes in Computer Science, vol.1122, pp.173-186, 1996. ,
DOI : 10.1007/3-540-61581-4_53
Chain homotopies for object topological representations, Discrete Applied Mathematics, vol.157, issue.3, pp.490-499, 2009. ,
DOI : 10.1016/j.dam.2008.05.029
Cycle bases of graphs and sampled manifolds, Computer Aided Geometric Design, vol.24, issue.8-9, pp.464-480, 2007. ,
DOI : 10.1016/j.cagd.2006.07.001
Asymptotically Fast Triangularization of Matrices over Rings, SIAM Journal on Computing, vol.20, issue.6, pp.1068-1083, 1991. ,
DOI : 10.1137/0220067
Algebraic Topology. Cambr, 2002. ,
A two-level topological decomposition for non-manifold simplicial shapes, Proceedings of the 2007 ACM symposium on Solid and physical modeling , SPM '07, pp.355-260, 2007. ,
DOI : 10.1145/1236246.1236297
Homology computation by reduction of chain complexes, Computers & Mathematics with Applications, vol.35, issue.4, pp.35-39, 1998. ,
DOI : 10.1016/S0898-1221(97)00289-7
Polynomial Algorithms for Computing the Smith and Hermite Normal Forms of an Integer Matrix, SIAM Journal on Computing, vol.8, issue.4, pp.499-507, 1979. ,
DOI : 10.1137/0208040
Homology algorithm based on acyclic subspace, Computers & Mathematics with Applications, vol.55, issue.11, pp.2395-2412, 2008. ,
DOI : 10.1016/j.camwa.2007.08.044
Algebraic Topology, 1999. ,
Directly computing the generators of image homology using graph pyramids, Image and Vision Computing, vol.27, issue.7, pp.846-853, 2009. ,
DOI : 10.1016/j.imavis.2008.06.009
URL : https://hal.archives-ouvertes.fr/hal-00366086
The Computability Problem in Algebraic Topology, Advances in Mathematics, vol.104, issue.1, pp.139-155, 1994. ,
DOI : 10.1006/aima.1994.1018
Constructive algebraic topology, ACM SIGSAM Bulletin, vol.33, issue.3, pp.13-25, 1999. ,
DOI : 10.1145/347127.347138
URL : https://hal.archives-ouvertes.fr/hal-00126384
Constructive homological algebra and applications, 2006. ,
Near optimal algorithms for computing Smith normal forms of integer matrices, Proceedings of the 1996 international symposium on Symbolic and algebraic computation , ISSAC '96, pp.267-274, 1996. ,
DOI : 10.1145/236869.237084
A survey of CAD model simplification techniques for physics-based simulation applications, Computer-Aided Design, vol.41, issue.2, pp.65-80, 2009. ,
DOI : 10.1016/j.cad.2008.11.009
Topological Data Processing for Distributed Sensor Networks with Morse-Smale Decomposition, IEEE INFOCOM 2009, The 28th Conference on Computer Communications, pp.2911-2915, 2009. ,
DOI : 10.1109/INFCOM.2009.5062257
Localized homology, Computational Geometry, vol.41, issue.3, pp.126-148, 2008. ,
DOI : 10.1016/j.comgeo.2008.02.003
URL : http://doi.org/10.1016/j.comgeo.2008.02.003
