l1-penalized projected Bellman residual - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthieu Geist
Bruno Scherrer
We consider the task of feature selection for value function approximation in reinforcement learning. A promising approach consists in combining the Least-Squares Temporal Difference (LSTD) algorithm with $\ell_1$-regularization, which has proven to be effective in the supervised learning community. This has been done recently whit the LARS-TD algorithm, which replaces the projection operator of LSTD with an $\ell_1$-penalized projection and solves the corresponding fixed-point problem. However, this approach is not guaranteed to be correct in the general off-policy setting. We take a different route by adding an $\ell_1$-penalty term to the projected Bellman residual, which requires weaker assumptions while offering a comparable performance. However, this comes at the cost of a higher computational complexity if only a part of the regularization path is computed. Nevertheless, our approach ends up to a supervised learning problem, which let envision easy extensions to other penalties.
gs_ewrl_l1_cr.pdf (236.6 Ko) Télécharger le fichier
hal-00644507 , version 1 (24-11-2011)
  • HAL Id : hal-00644507 , version 1
Matthieu Geist, Bruno Scherrer. l1-penalized projected Bellman residual. European Wrokshop on Reinforcement Learning (EWRL 11), Sep 2011, Athens, Greece. ⟨hal-00644507⟩
195 Consultations
469 Téléchargements
