An integrated simdization framework using virtual vectors, Proceedings of the 19th annual international conference on Supercomputing , ICS '05, 2005. ,
DOI : 10.1145/1088149.1088172
The Software Vectorization Handbook. Applying Multimedia Extensions for Maximum Performance, 2004. ,
Automatic intra-register vectorization for the Intel architecture, IJPP, vol.30, issue.2, pp.65-98, 2002. ,
Autovectorization in GCC ? two years later, " in the GCC Developer's summit, 2006. ,
Superword-level parallelism in the presence of control flow, CGO, 2005. ,
Outer-loop vectorization -revisited for short SIMD architectures, PACT, 2008. ,
DOI : 10.1145/1454115.1454119
Optimizing Compilers for Modern Architectures, 2001. ,
A practical automatic polyhedral parallelization and locality optimization system, PLDI, 2008. ,
Iterative optimization in the polyhedral model: Part II, multidimensional time, PLDI, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
Automatic translation of FORTRAN programs to vector form, ACM Transactions on Programming Languages and Systems, vol.9, issue.4, pp.491-542, 1987. ,
DOI : 10.1145/29873.29875
High Performance Compilers for Parallel Computing, 1996. ,
Compiler-controlled caching in superword register files for multimedia extension architectures, PACT, 2002. ,
Auto-vectorization of interleaved data for simd, PLDI, 2006. ,
Compile-Time Based Performance Prediction, LCPC, 1999. ,
DOI : 10.1007/3-540-44905-1_23
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.46.9836
Probabilistic miss equations: evaluating memory hierarchy performance, IEEE Transactions on Computers, vol.52, issue.3, pp.321-336, 2003. ,
DOI : 10.1109/TC.2003.1183947
Array expansion, ICS, 1988. ,
DOI : 10.1145/2591635.2667159
URL : https://hal.archives-ouvertes.fr/hal-01099746
Semi-Automatic Composition of Loop Transformations for Deep Parallelism and Memory Hierarchies, International Journal of Parallel Programming, vol.20, issue.1, pp.261-317, 2006. ,
DOI : 10.1007/s10766-006-0012-3
URL : https://hal.archives-ouvertes.fr/hal-01257288
Some efficient solutions to the affine scheduling problem. Part II. Multidimensional time, International Journal of Parallel Programming, vol.2, issue.4, pp.389-420315, 1992. ,
DOI : 10.1007/BF01379404
A framework for unifying reordering transformations, 1993. ,
Maximizing parallelism and minimizing synchronization with affine transforms, Proceedings of the 24th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '97, pp.201-214, 1997. ,
DOI : 10.1145/263699.263719
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
