M. Kass, A. Witkin, and D. Terzopoulos, Snakes: Active contour models, International Journal of Computer Vision, vol.5, issue.6035, pp.321-331, 1988.
DOI : 10.1007/BF00133570
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5318
D. Terzopoulos and D. Metaxas, Dynamic 3D models with local and global deformations: deformable superquadrics, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.7, pp.703-714, 1991.
DOI : 10.1109/34.85659
F. Precioso, M. Barlaud, T. Blu, and M. Unser, Robust real-time segmentation of images and videos using a smooth-spline snake-based algorithm, IEEE Transactions on Image Processing, vol.14, issue.7, pp.910-924, 2005.
DOI : 10.1109/TIP.2005.849307
URL : https://hal.archives-ouvertes.fr/hal-01343201
V. Caselles, R. Kimmel, and G. Sapiro, Geodesic active contours, Proceedings of IEEE International Conference on Computer Vision, pp.61-79, 1997.
DOI : 10.1109/ICCV.1995.466871
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.21.2196
C. Xu, J. Yezzi, A. , and J. L. Prince, A summary of geometric level-set analogues for a general class of parametric active contour and surface models, IEEE Workshop on Variational and Level Set Methods in Computer Vision, pp.104-111, 2001.
C. Collewet, Polar snakes: A fast and robust parametric active contour model, 2009 16th IEEE International Conference on Image Processing (ICIP), pp.3013-3016, 2009.
DOI : 10.1109/ICIP.2009.5414444
URL : https://hal.archives-ouvertes.fr/inria-00629794
S. Impedovo, B. Marangelli, and A. M. Fanelli, A fourier descriptor set for recognizing nonstylized numerals, IEEE Tran. on Systems, Man and Cybernetics, vol.8, issue.8, pp.640-645, 1978.
H. Freeman and L. S. Davis, A Corner-Finding Algorithm for Chain-Coded Curves, IEEE Transactions on Computers, vol.26, issue.3, pp.297-303, 1977.
DOI : 10.1109/TC.1977.1674825
Z. Yang, Y. Zhu, and Y. Pu, Parallel Image Processing Based on CUDA, 2008 International Conference on Computer Science and Software Engineering, pp.198-201, 2008.
DOI : 10.1109/CSSE.2008.1448
N. Otsu, A Threshold Selection Method from Gray-Level Histograms, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.1, pp.62-66, 1979.
DOI : 10.1109/TSMC.1979.4310076
R. Mebarki, A. Krupa, and F. Chaumette, 2-D Ultrasound Probe Complete Guidance by Visual Servoing Using Image Moments, IEEE Transactions on Robotics, vol.26, issue.2, pp.296-306, 2010.
DOI : 10.1109/TRO.2010.2042533
URL : https://hal.archives-ouvertes.fr/inria-00544791
