Parametric Multi-Level Tiling of Imperfectly Nested Loops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Tiling is a crucial loop transformation for generating high perfor- mance code on modern architectures. Efficient generation of multi- level tiled code is essential for maximizing data reuse in systems with deep memory hierarchies. Tiled loops with parametric tile sizes (not compile-time constants) facilitate runtime feedback and dynamic optimizations used in iterative compilation and automatic tuning. Previous parametric multi-level tiling approaches have been restricted to perfectly nested loops, where all assignment state- ments are contained inside the innermost loop of a loop nest. Pre- vious solutions to tiling for imperfect loop nests have only handled fixed tile sizes. In this paper, we present an approach to paramet- ric multi-level tiling of imperfectly nested loops. The tiling tech- nique generates loops that iterate over full rectangular tiles, making them amenable to compiler optimizations such as register tiling. Experimental results using a number of computational benchmarks demonstrate the effectiveness of the developed tiling approach.
ics260-hartono-final.pdf (283.65 Ko) Télécharger le fichier
hal-00645328 , version 1 (28-11-2011)
  • HAL Id : hal-00645328 , version 1
Albert Hartono, Muthu M. Baskaran, Cédric Bastoul, Albert Cohen, Sriram Krishnamoorthy, et al.. Parametric Multi-Level Tiling of Imperfectly Nested Loops. 23rd International Conference on Supercomputing, Jun 2009, Yorkton Heights, New York, United States. ⟨hal-00645328⟩
429 Consultations
549 Téléchargements
