Tiling Imperfectly-nested Loop Nests, ACM/IEEE SC 2000 Conference (SC'00), 2000. ,
DOI : 10.1109/SC.2000.10018
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.491
Synthesizing transformations for locality enhancement of imperfectly-nested loop nests, IJPP, vol.29, issue.5, 2001. ,
Scanning polyhedra with do loops, PPoPP'91, pp.39-50, 1991. ,
URL : https://hal.archives-ouvertes.fr/hal-00752774
Efficient code generation for automatic parallelization and optimization, Second International Symposium on Parallel and Distributed Computing, 2003. Proceedings., p.23, 2003. ,
DOI : 10.1109/ISPDC.2003.1267639
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
A practical automatic polyhedral program optimization system, PLDI'08, 2008. ,
(Pen)-ultimate tiling? Integration, the VLSI Journal, pp.33-51, 1994. ,
Compiler blockability of numerical algorithms, Proceedings Supercomputing '92, pp.114-124, 1992. ,
DOI : 10.1109/SUPERC.1992.236704
Combining Models and Guided Empirical Search to Optimize for Multiple Levels of the Memory Hierarchy, International Symposium on Code Generation and Optimization, 2005. ,
DOI : 10.1109/CGO.2005.10
Chill: A framework for composing high-level loop transformations, 2008. ,
The Chunky Loop Generator ,
Tile Size Selection Using Cache Organization and Data Layout, PLDI'95, pp.279-290, 1995. ,
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1007/BF01407931
An efficient code generation technique for tiled iteration spaces, IEEE Transactions on Parallel and Distributed Systems, vol.14, issue.10, pp.1021-1034, 2003. ,
DOI : 10.1109/TPDS.2003.1239870
Primetile: A parametric multi-level tiler for imperfect loop nests, 2009. ,
Hierarchical Tiled Loop Generator Available at http://www.cs.colostate ,
Selecting tile shape for minimal execution time, Proceedings of the eleventh annual ACM symposium on Parallel algorithms and architectures , SPAA '99, pp.201-211, 1999. ,
DOI : 10.1145/305619.305641
Supernode partitioning, Proceedings of the 15th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '88, pp.319-329, 1988. ,
DOI : 10.1145/73560.73588
Register tiling in nonrectangular iteration spaces, ACM Transactions on Programming Languages and Systems, vol.24, issue.4, pp.409-453, 2002. ,
DOI : 10.1145/567097.567101
A cost-effective implementation of multilevel tiling, IEEE Transactions on Parallel and Distributed Systems, vol.14, issue.10, pp.1006-1020, 2003. ,
DOI : 10.1109/TPDS.2003.1239869
Parameterized tiling for imperfectly nested loops, 2009. ,
Multi-level tiling, Proceedings of the 2007 ACM/IEEE conference on Supercomputing , SC '07, 2001. ,
DOI : 10.1145/1362622.1362691
An affine partitioning algorithm to maximize parallelism and minimize communication, Proceedings of the 13th international conference on Supercomputing , ICS '99, pp.228-237, 1999. ,
DOI : 10.1145/305138.305197
Maximizing parallelism and minimizing synchronization with affine partitions, Parallel Computing, vol.24, issue.3-4, pp.3-4445, 1998. ,
DOI : 10.1016/S0167-8191(98)00021-0
Blocking and array contraction across arbitrarily nested loops using affine partitioning, PPoPP'01, 2001. ,
A polyhedral automatic parallelizer and locality optimizer for multicores ,
The Omega test: a fast and practical integer programming algorithm for dependence analysis, Proceedings of the 1991 ACM/IEEE conference on Supercomputing , Supercomputing '91, pp.102-114, 1992. ,
DOI : 10.1145/125826.125848
Generation of efficient nested loops from polyhedra, IJPP, vol.28, issue.5, pp.469-498, 2000. ,
Tiling multidimensional iteration spaces for multicomputers, Journal of Parallel and Distributed Computing, vol.16, issue.2, pp.108-230, 1992. ,
DOI : 10.1016/0743-7315(92)90027-K
Parameterized tiled loops for free, PLDI'07, pp.405-414, 2007. ,
A Geometric Programming Framework for Optimal Multi-Level Tiling, Proceedings of the ACM/IEEE SC2004 Conference, 2004. ,
DOI : 10.1109/SC.2004.3
Locality optimizations for multi-level caches, Proceedings of the 1999 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '99, 1999. ,
DOI : 10.1145/331532.331534
Automatic blocking of nested loops, 1990. ,
New tiling techniques to improve cache temporal locality, PLDI, pp.215-228, 1999. ,
DOI : 10.1145/301631.301668
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.37.3631
Scalable autotuning framework for compiler optimization, IPDPS '09, 2009. ,
A Parametrized Tiled Loop Generator Available at http://www.cs.colostate ,
Automatically Tuned Linear Algebra Software (ATLAS), Proc. Supercomputing '98, 1998. ,
Automated Empirical Optimizations of Software and the ATLAS Project, Parallel Computing Journal, 2000. ,
Tuning High Performance Kernels through Empirical Compilation, 2005 International Conference on Parallel Processing (ICPP'05), pp.89-98, 2005. ,
DOI : 10.1109/ICPP.2005.77
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.297.6378
Loop tiling for parallelism, 2000. ,
DOI : 10.1007/978-1-4615-4337-4
Transforming Complex Loop Nests for Locality, The Journal of Supercomputing, vol.27, issue.3, pp.219-264, 2004. ,
DOI : 10.1023/B:SUPE.0000011386.69245.f5
