Estimation of the Effective Self-Diffusion Tensor from the NMR Spin Echo, Journal of Magnetic Resonance, Series B, vol.103, issue.3, pp.247-254, 1994. ,
DOI : 10.1006/jmrb.1994.1037
URL : https://hal.archives-ouvertes.fr/hal-00349722
MR diffusion tensor spectroscopy and imaging, Biophysical Journal, vol.66, issue.1, pp.259-267, 1994. ,
DOI : 10.1016/S0006-3495(94)80775-1
URL : https://hal.archives-ouvertes.fr/hal-00349721
Q-ball imaging, Magnetic Resonance in Medicine, vol.23, issue.6, pp.1358-1372, 2004. ,
DOI : 10.1002/mrm.20279
Regularized, fast, and robust analytical Q-ball imaging, Magnetic Resonance in Medicine, vol.17, issue.3, pp.497-510, 2007. ,
DOI : 10.1002/mrm.21277
Reconstruction of the orientation distribution function in single- and multiple-shell q-ball imaging within constant solid angle, Magnetic Resonance in Medicine, vol.27, issue.2, pp.554-566, 2010. ,
DOI : 10.1002/mrm.22365
A new methodology for the estimation of fiber populations in the white matter of the brain with the Funk???Radon transform, NeuroImage, vol.49, issue.2, pp.1301-1315, 2010. ,
DOI : 10.1016/j.neuroimage.2009.09.070
blue indicates low anisotropy (local trough) (Voxel) Line-colour: thick-green: Maxima, thin-green: Minima, fine-blue: Saddle points Fig. 3. RGB representation: red:X, green:Y, blue:Z. Left: DTI eigenvector, brightness: FA. Centre: ODF-T maximum, brightness: corresponding PFA-T. Right: ODF-SA maximum ,
(f) Total-PFA-SA from ODF-SA. 3rd column: Number-of-maxima from (c) ODF-T and (g) ODF-SA. Total-PFA measures the starriness or peakedness of an SF and emphasizes local sub-voxel anisotropy. Green arrow indicates regions with no crossings (dark in 3rd col.) but high local anisotropy (bright in Total-PFA) like the CC and the CST. Red arrow indicates regions with many crossings (bright in 3rd col.) and with high local anisotropy (bright in Total-PFA) like where the CC, CST and SLF intersect. However, these regions have low GFA values. Orange arrow indicates regions with high crossings (bright in 3rd col.) but with low local anisotropy (dark in Total-PFA) These regions also Persistent angular structure: new insights fom diffusion magnetic resonance imaging data, Fig. Inverse Problems, vol.4, issue.19, pp.1031-1046, 2003. ,
Direct estimation of the fiber orientation density function from diffusion-weighted MRI data using spherical deconvolution, NeuroImage, vol.23, issue.3, pp.1176-1185, 2004. ,
DOI : 10.1016/j.neuroimage.2004.07.037
On Computing the Underlying Fiber Directions from the Diffusion Orientation Distribution Function, MICCAI '08: Proceedings of the 11th international conference on Medical Image Computing and Computer-Assisted Intervention -Part I, pp.1-8, 2008. ,
DOI : 10.1007/978-3-540-85988-8_1
A polynomial based approach to extract the maxima of an antipodally symmetric spherical function and its application to extract fiber directions from the orientation distribution function in diffusion mri, Proceedings of Workshop on Computational Diffusion MRI, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00340600
ODF Maxima Extraction in Spherical Harmonic Representation via Analytical Search Space Reduction, MICCAI, pp.84-91, 2010. ,
DOI : 10.1007/978-3-642-15745-5_11
Apparent diffusion coefficients from high angular resolution diffusion imaging: Estimation and applications, Magnetic Resonance in Medicine, vol.50, issue.2, pp.395-410, 2006. ,
DOI : 10.1002/mrm.20948
Subdivision methods for solving polynomial equations, Journal of Symbolic Computation, vol.44, issue.3, pp.292-306, 2009. ,
DOI : 10.1016/j.jsc.2008.04.016
URL : https://hal.archives-ouvertes.fr/inria-00070350
Hessian sufficiency for bordered hessian, Res. Lett. Inf. Math. Sci, vol.8, pp.189-196, 2005. ,
A linear and regularized odf estimation algorithm to recover multiple fibers in q-ball imaging, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070253
Connectivity-Based Parcellation of Broca's Area, Cerebral Cortex, vol.17, issue.4, pp.816-825, 2007. ,
DOI : 10.1093/cercor/bhk034
