About the Defectivity of Certain SegreVeronese Varieties, Canadian Journal of Mathematics, vol.60, issue.5, 2008. ,
Secant varieties of Segre-Veronese varieties P m ×P n embedded by, Experimental Mathematics, pp.369-384, 2009. ,
On the virtual array concept for higher order array processing, IEEE Trans. Sig. Proc, vol.53, issue.4, pp.1254-1271, 2005. ,
Polynomial interpolation in several variables, J. Alg. Geom, vol.4, pp.201-222, 1995. ,
An asymptotic vanishing theorem for generic unions of multiple points, Inventiones Mathematicae, vol.140, issue.2, pp.303-325, 2000. ,
DOI : 10.1007/s002220000053
Algebraic Complexity Theory, Grund. der Math. Wiss, vol.315, 1997. ,
Secant dimensions of low-dimensional homogeneous varieties, Preprint arXiv:math, RT, pp.707-1605, 2007. ,
On the Alexander-Hirschowitz theorem, J. Pure Appl. Algebra, vol.212, issue.5, pp.1229-1251, 2008. ,
On Waring's problem for several algebraic forms, Comment . Math. Helv, vol.78, issue.3, pp.494-517, 2003. ,
The Grassmannians of secant varieties of curves are not defective, Indag. Math, vol.13, pp.23-28, 2002. ,
Higher secant varieties of Segre- Veronese varieties, Projective varieties with unexpected properties, pp.81-107, 2005. ,
Optimal separation of independent narrow-band sources -concept and performance Special issue on blind separation and deconvolution. [Co1] P. Comon, Independent Component Analysis, Higher Order Statistics, pp.27-48, 1992. ,
Tensor decompositions, Math. Signal Processing, 2002. ,
Blind identification of under-determined mixtures based on the characteristic function, Signal Process, pp.2271-2281, 2006. ,
Tensor-based techniques for the blind separation of DS???CDMA signals, Signal Processing, vol.87, issue.2, pp.322-336, 2007. ,
DOI : 10.1016/j.sigpro.2005.12.015
A Multilinear Singular Value Decomposition, SIAM Journal on Matrix Analysis and Applications, vol.21, issue.4, pp.1253-1278, 2000. ,
DOI : 10.1137/S0895479896305696
Applications of cumulants to array processing .I. aperture extension and array calibration, IEEE Trans. Sig. Proc, vol.43, issue.5, pp.1200-1216, 1995. ,
Decomposable tensors as a quadratic variety, Proc. Am, pp.227-230, 1977. ,
Kruskal's Permutation Lemma and the Identification of CANDECOMP/PARAFAC and Bilinear Models with Constant Modulus Constraints, IEEE Transactions on Signal Processing, vol.52, issue.9, pp.2625-2636, 2004. ,
DOI : 10.1109/TSP.2004.832022
Algebraic Geometry, a First Course, 1993. ,
Ueber die Polarfiguren der ebenen Curven dritter Ordnung, Typical tensorial rank, pp.535-584, 1890. ,
Parallel factor analysis in sensor array processing, IEEE Trans. Signal Processing, pp.48-2377, 2000. ,
Rank and optimal computation of generic tensor Sulle V k per cui la varietà degli S h (h + 1)-seganti ha dimensione minore dell'ordinario, Rend, Linear Algebra Appl. Circ. Mat. Palermo, vol.52, pp.645-685, 1911. ,
Sulla rappresentazione delle coppie di forme ternarie mediante somme di potenze di forme lineari, pp.91-100, 1915. ,
Tangents and Secants of Algebraic Varieties (Translations of, Math.Monographs, vol.127, 1993. ,
38123 Povo (Trento), Italy E-mail address, E-mail address: enrico.carlini@polito.it (M.V.Catalisano) DIPTEM -Dipartimento di Ingegneria della Produzione, Termoenergetica e Modelli Matematici ,
E-mail address: catalisano@diptem.unige ,
