Decomposition of homogeneous polynomials with low rank - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematische Zeitschrift Année : 2012
Let $F$ be a homogeneous polynomial of degree $d$ in $m+1$ variables defined over an algebraically closed field of characteristic 0 and suppose that $F$ belongs to the $s$-th secant variety of the $d$-uple Veronese embedding of $\mathbb{P}^m$ into $ \PP {{m+d\choose d}-1}$ but that its minimal decomposition as a sum of $d$-th powers of linear forms $M_1, \ldots , M_r$ is $F=M_1^d+\cdots + M_r^d$ with $r>s$. We show that if $s+r\leq 2d+1$ then such a decomposition of $F$ can be split in two parts: one of them is made by linear forms that can be written using only two variables, the other part is uniquely determined once one has fixed the first part. We also obtain a uniqueness theorem for the minimal decomposition of $F$ if $r$ is at most $d$ and a mild condition is satisfied.
pollo2.pdf (252.25 Ko) Télécharger le fichier
hal-00645978 , version 1 (28-11-2011)
Edoardo Ballico, Alessandra Bernardi. Decomposition of homogeneous polynomials with low rank. Mathematische Zeitschrift, 2012, 271, pp.1141-1149. ⟨10.1007/s00209-011-0907-6⟩. ⟨hal-00645978⟩
161 Consultations
183 Téléchargements
