On the X-rank with respect to linear projections of projective varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical News / Mathematische Nachrichten Année : 2011
In this paper we improve the known bound for the $X$-rank $R_{X}(P)$ of an element $P\in {\mathbb{P}}^N$ in the case in which $X\subset {\mathbb P}^n$ is a projective variety obtained as a linear projection from a general $v$-dimensional subspace $V\subset {\mathbb P}^{n+v}$. Then, if $X\subset {\mathbb P}^n$ is a curve obtained from a projection of a rational normal curve $C\subset {\mathbb P}^{n+1}$ from a point $O\subset {\mathbb P}^{n+1}$, we are able to describe the precise value of the $X$-rank for those points $P\in {\mathbb P}^n$ such that $R_{X}(P)\leq R_{C}(O)-1$ and to improve the general result. Moreover we give a stratification, via the $X$-rank, of the osculating spaces to projective cuspidal projective curves $X$. Finally we give a description and a new bound of the $X$-rank of subspaces both in the general case and with respect to integral non-degenerate projective curves.
hal-00646117 , version 1 (29-11-2011)
Edoardo Ballico, Alessandra Bernardi. On the X-rank with respect to linear projections of projective varieties. Mathematical News / Mathematische Nachrichten, 2011, 284 (17-18), pp.2133-2140. ⟨10.1002/mana.200910275⟩. ⟨hal-00646117⟩
126 Consultations
0 Téléchargements
