On the X-rank with respect to linearly normal curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Collectanea Mathematica Année : 2011
In this paper we study the $X$-rank of points with respect to smooth linearly normal curves $X\subset \PP n$ of genus $g$ and degree $n+g$. We prove that, for such a curve $X$, under certain circumstances, the $X$-rank of a general point of $X$-border rank equal to $s$ is less or equal than $n+1-s$. In the particular case of $g=2$ we give a complete description of the $X$-rank if $n=3,4$; while if $n\geq 5$ we study the $X$-rank of points belonging to the tangential variety of $X$.
hal-00646161 , version 1 (29-11-2011)
Edoardo Ballico, Alessandra Bernardi. On the X-rank with respect to linearly normal curves. Collectanea Mathematica, 2011, 64 (2), pp.141-154. ⟨10.1007/s13348-011-0058-4⟩. ⟨hal-00646161⟩
175 Consultations
0 Téléchargements
