A Stochastic-Dynamic Model for the Spatial Structure of Forecast Error Statistics, Monthly Weather Review, vol.111, issue.4, pp.701-722, 1983. ,
DOI : 10.1175/1520-0493(1983)111<0701:ASDMFT>2.0.CO;2
Toward Optimal Choices of Control Space Representation for Geophysical Data Assimilation, Monthly Weather Review, vol.137, issue.7, pp.2331-2348, 2009. ,
DOI : 10.1175/2009MWR2789.1
URL : https://hal.archives-ouvertes.fr/inria-00566025
Bayesian design of control space for optimal assimilation of observations. Part II: Asymptotic solutions, Quarterly Journal of the Royal Meteorological Society, vol.111, issue.658, pp.1357-1368, 2011. ,
DOI : 10.1002/qj.841
URL : https://hal.archives-ouvertes.fr/inria-00632593
Bayesian design of control space for optimal assimilation of observations. Part I: Consistent multiscale formalism, Quarterly Journal of the Royal Meteorological Society, vol.136, issue.658, pp.1340-1356, 2011. ,
DOI : 10.1002/qj.837
Regional changes in carbon dioxide fluxes of land and oceans since, Science, issue.5495, pp.290-1342, 1980. ,
What can we learn from European continuous atmospheric CO<sub>2</sub> measurements to quantify regional fluxes ??? Part 2: Sensitivity of flux accuracy to inverse setup, Atmospheric Chemistry and Physics, vol.10, issue.6, pp.3119-3129, 2010. ,
DOI : 10.5194/acp-10-3119-2010
On the assignment of prior errors in Bayesian inversions of CO 2 surface fluxes, Geophys. Res. Lett, pp.10-1029, 2006. ,
Contribution of the orbiting carbon observatory to the estimation of CO 2 sources and sinks: Theoretical study in a variational data assimilation framework, J. Geophys. Res, vol.112, pp.930710-1029, 2007. ,
Inverse Problems in Atmospheric Constituent Transport, 2002. ,
DOI : 10.1017/CBO9780511535741
A Large Terrestrial Carbon Sink in North America Implied by Atmospheric and Oceanic Carbon Dioxide Data and Models, Science, vol.282, issue.5388, pp.282-442, 1998. ,
DOI : 10.1126/science.282.5388.442
Toward constraining regional? scale fluxes of CO 2 with atmospheric observations over a continent: 2. Analysis of COBRA data using a receptor?oriented framework, J. Geophys. Res, vol.108, issue.D24, p.475710, 1029. ,
What can tracer observations in the continental boundary layer tell us about surface-atmosphere fluxes?, Atmospheric Chemistry and Physics, vol.6, issue.2, pp.539-554, 2006. ,
DOI : 10.5194/acp-6-539-2006
URL : https://hal.archives-ouvertes.fr/hal-00295849
Regional-scale geostatistical inverse modeling of North American CO<sub>2</sub> fluxes: a synthetic data study, Atmospheric Chemistry and Physics, vol.10, issue.13, pp.6151-6167, 2010. ,
DOI : 10.5194/acp-10-6151-2010
On aggregation errors in atmospheric transport inversions, Journal of Geophysical Research: Atmospheres, vol.271, issue.D5, pp.4703-4715, 2001. ,
DOI : 10.1029/2000JD900581
Mesoscale inversion: first results from the CERES campaign with synthetic data, Atmospheric Chemistry and Physics, vol.8, issue.13, pp.3459-3471, 2008. ,
DOI : 10.5194/acp-8-3459-2008
URL : https://hal.archives-ouvertes.fr/hal-00328218
Bridging the gap between atmospheric concentrations and local ecosystem measurements, Geophysical Research Letters, vol.247, issue.19, pp.10-1029, 2009. ,
DOI : 10.1029/2009GL039574
URL : https://hal.archives-ouvertes.fr/ird-00406789
Data and modelling requirements for CO2 inversions using high-frequency data, Tellus B, vol.106, issue.4, pp.512-521, 2003. ,
DOI : 10.1016/S0967-0645(02)00003-6
A near-field tool for simulating the upstream influence of atmospheric observations: The Stochastic Time-Inverted Lagrangian Transport (STILT) model, Journal of Geophysical Research, vol.108, issue.D16, p.449310, 1029. ,
DOI : 10.1029/2002JD003161
Incorporation of crop phenology in Simple Biosphere Model (SiBcrop) to improve land-atmosphere carbon exchanges from croplands, Biogeosciences, vol.6, issue.6, pp.969-986, 2009. ,
DOI : 10.5194/bg-6-969-2009
A geostatistical approach to surface flux estimation of atmospheric trace gases, Journal of Geophysical Research, vol.34, issue.6, pp.10-1029, 2004. ,
DOI : 10.1029/2003JD004422
An atmospheric perspective on North American carbon dioxide exchange: CarbonTracker, Proceedings of the National Academy of Sciences, vol.104, issue.48, pp.925-18930, 2007. ,
DOI : 10.1073/pnas.0708986104
Inverse modeling of atmospheric carbon dioxide fluxes ? Response, Science, issue.5550, pp.294-2292, 2001. ,
Daily CO<sub>2</sub> flux estimates over Europe from continuous atmospheric measurements: 1, inverse methodology, Daily CO 2 flux estimates over Europe from continuous atmospheric measurements: 1. Inverse methodology, pp.3173-3186, 2005. ,
DOI : 10.5194/acp-5-3173-2005
Atmospheric CO 2 inversion validation using vertical profile measurements: Analysis of four independent inversion models, J. Geophys. Res, pp.10-1029, 2011. ,
CO<sub>2</sub> flux history 1982???2001 inferred from atmospheric data using a global inversion of atmospheric transport, Atmospheric Chemistry and Physics, vol.3, issue.6, pp.1919-1964, 2003. ,
DOI : 10.5194/acp-3-1919-2003
Constraining surface emissions of air pollutants using inverse modeling: method intercomparison and a new two?step two?scale regularization approach, pp.360-370, 2011. ,
A regional high?resolution carbon flux inversion of North America for, Biogeosciences, issue.5, pp.7-1625, 2004. ,
Source-receptor matrix calculation with a Lagrangian particle dispersion model in backward mode, Atmospheric Chemistry and Physics, vol.4, issue.1, pp.51-63, 2004. ,
DOI : 10.5194/acp-4-51-2004
URL : https://hal.archives-ouvertes.fr/hal-00295385
Modelling representation errors of atmospheric CO<sub>2</sub> mixing ratios at a regional scale, Atmospheric Chemistry and Physics, vol.8, issue.22, pp.6587-6596, 2008. ,
DOI : 10.5194/acp-8-6587-2008
Lagrangian particle dispersion modeling in mesoscale applications, in Environmental Modeling II, Comput. Mech, pp.71-102, 1994. ,
Laboratoire des Sciences du Climat et de l ,
