Unification of Register Allocation and Instruction Scheduling in Compilers for Fine-Grain Parallel Architecture, 1996. ,
FRIGG: A New Approach to Combining Register Assignment and Instruction Scheduling, 1994. ,
On a graph-theoretical model for cyclic register allocation, Discrete Applied Mathematics, vol.93, issue.2-3, pp.191-203, 1999. ,
DOI : 10.1016/S0166-218X(99)00105-5
Allocating Registers in Multiple Instruction-Issuing Processors, Proceedings of the IFIP WG 10.3 Working Conference on Parallel Architectures and Compilation Techniques, PACT'95, pp.290-293, 1995. ,
URL : https://hal.archives-ouvertes.fr/inria-00074059
Phase Ordering of Register Allocation and Instruction Scheduling, Code Generation ? Concepts, Tools, Techniques. Proceedings of the International Workshop on Code Generation, pp.146-172, 1992. ,
DOI : 10.1007/978-1-4471-3501-2_9
Minimum register instruction sequence problem: revisiting optimal code generation for DAGs, Proceedings 15th International Parallel and Distributed Processing Symposium. IPDPS 2001, pp.26-26, 2001. ,
DOI : 10.1109/IPDPS.2001.924962
WBTK: A New Set of Microbenchmarks to Explore Memory System Performance, Los Alamos Computer Science Institute (LACSI) Symposium, 2002. ,
Compilers Strategies for Transport Triggered Architectures, 2001. ,
Code Optimization by Integer Linear Programming, Lecture Notes in Computer Science, vol.1575, pp.122-136, 1999. ,
DOI : 10.1007/978-3-540-49051-7_9
Dual-Issue Scheduling for Binary Trees with Spills and Pipelined Loads, SIAM Journal on Computing, vol.30, issue.6, pp.1921-1941, 2001. ,
DOI : 10.1137/S009753979834610X
A Scheduler-Sensitive Global Register Allocator, IEEE Supercomputing 93 Proceedings, pp.804-813, 1993. ,
Register Allocation with Instruction Scheduling: A New Approach, SIGPLAN Notices, vol.28, issue.6, pp.248-257, 1993. ,
A register pressure sensitive instruction scheduler for dynamic issue processors, Proceedings 1997 International Conference on Parallel Architectures and Compilation Techniques, pp.78-89, 1997. ,
DOI : 10.1109/PACT.1997.644005
Register Saturation in Superscalar and VLIW Codes, Proceedings of The International Conference on Compiler Construction, 2001. ,
DOI : 10.1007/3-540-45306-7_15
URL : https://hal.archives-ouvertes.fr/inria-00637277
Register Pressure in Instruction Level Parallelisme, 2002. ,
URL : https://hal.archives-ouvertes.fr/tel-00007405
