On enabling dependability assurance in heterogeneous networks through automated model-based analysis
We present the specifi cation of a basic library of dependability mechanisms that can be used within automated approaches for synthesising dependable Connectors in heterogeneous networks. The library builds on classical dependability patterns, such as majority voting and retry, and uses the concept of overlay networks for triggering the synthesis of speci fic dependability mechanisms in the Connector from high-level specifi cations. We translated such dependability mechanisms into SAN models with the aim to evaluate, through model-based analysis, which dependability mechanisms should be embedded in the synthesised Connector for ensuring a given dependability level between networked systems willing to be connected. A case study is also presented to show the application of selected library mechanisms. This work is carried out in the context of Connect, a European FET project which is investigating the possibility of enabling long-lasting inter-operation among networked systems by synthesising mediating Connectors at run-time.
