A method for solving key equation for decoding goppa codes, Information and Control, vol.27, issue.1, pp.87-99, 1975. ,
DOI : 10.1016/S0019-9958(75)90090-X
Algebraic coding theory, 1968. ,
DOI : 10.1142/9407
A Generalized Euclidean Algorithm for Multisequence Shift-Register Synthesis Information Theory, IEEE Transactions on, vol.3518, issue.3, pp.584-59430981, 1989. ,
Linear Shift-Register Synthesis for Multiple Sequences of Varying Length, p.605044, 2006. ,
Euclidean Modules and Multisequence Synthesis, " in Applied Algebra, Algebraic Algorithms and Error-Correcting Codes, ser, Lecture Notes in Computer Science, S. Boztas¸andBoztas¸Boztas¸and I. E ,
Reed-Solomon Codes for Correcting Phased Error Bursts Information Theory, IEEE Transactions on, vol.49, issue.11, pp.2975-2984819333, 2003. ,
Decoding interleaved Reed???Solomon codes over noisy channels, Theoretical Computer Science, vol.379, issue.3, pp.348-360, 2007. ,
DOI : 10.1016/j.tcs.2007.02.043
URL : http://doi.org/10.1016/j.tcs.2007.02.043
Decoding of Reed Solomon Codes beyond the Error-Correction Bound, Journal of Complexity, vol.13, issue.1, pp.180-193, 1997. ,
DOI : 10.1006/jcom.1997.0439
On the Equivalence of Sudan- Decoding and Decoding via Virtual Extension to an Interleaved Reed- Solomon Code, 8th International ITG Conference on Source and Channel Coding ,
URL : https://hal.archives-ouvertes.fr/hal-00647618
Decoding Reed- Solomon Codes Beyond Half the Minimum Distance using Shift- Register Synthesis Available: http: //ieeexplore.ieee.org/xpls/abs all.jsp?arnumber=4036003 APPENDIX We consider a RS(10, 3) code over F = GF (11) For the virtual extension of Section III, Information Theory IEEE International Symposium on, pp.459-463, 2006. ,
