On the Equivalence of Sudan-Decoding and Decoding via Virtual Extension to an Interleaved Reed-Solomon Code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we investigate two new decoding schemes for Reed-Solomon codes, which allow to decode beyond half the minimum distance. One is Sudan's list-decoding principle, based on interpolation with a degree-restricted bivariate polynomial. We show a syndrome-based approach of it. We compare Sudan's procedure with a scheme that is based on an extension to Interleaved Reed-Solomon codes. We present theoretical parallels and outline both algorithms in a unique comparable way. Furthermore, we show the connection of both schemes to the classical Linear Feedback Shift Register analysis. Afterwards, we compare the performance of the considered schemes.
SCC2010.pdf (2.28 Mo) Télécharger le fichier
hal-00647618 , version 1 (02-12-2011)
  • HAL Id : hal-00647618 , version 1
Alexander Zeh, Sabine Kampf, Martin Bossert. On the Equivalence of Sudan-Decoding and Decoding via Virtual Extension to an Interleaved Reed-Solomon Code. International ITG Conference on Source and Channel Coding (SCC), Jan 2010, Siegen, Germany. pp.1-6. ⟨hal-00647618⟩
329 Consultations
120 Téléchargements
