Data-aggregation techniques in sensor networks: a survey, IEEE Communications Surveys & Tutorials, vol.8, issue.4, pp.48-63, 2006. ,
DOI : 10.1109/COMST.2006.283821
A survey on clustering algorithms for wireless sensor networks, Computer Communications, vol.30, issue.14-15, pp.2826-2841, 2007. ,
DOI : 10.1016/j.comcom.2007.05.024
Exploiting heterogeneity in sensor networks, Proceedings IEEE 24th Annual Joint Conference of the IEEE Computer and Communications Societies., 2005. ,
DOI : 10.1109/INFCOM.2005.1498318
Guest Editors' Introduction: Energy Harvesting and Conservation, IEEE Pervasive Computing, vol.4, issue.1, pp.14-17, 2005. ,
DOI : 10.1109/MPRV.2005.12
Topology control in heterogeneous wireless networks: Problems and solutions, Proceedings of the 23 rd Joint Conference of the IEEE Computer and Communications Societies INFOCOM, 2004. ,
Wireless Sensor Network Protocols, fundamental algorithms and protocols for wireless and mobile networks ed, 2005. ,
Energy conservation in wireless sensor networks: A survey, Ad Hoc Networks, pp.537-568, 2009. ,
DOI : 10.1016/j.adhoc.2008.06.003
Improving network lifetime with mobile wireless sensor networks, Computer Communications, vol.33, issue.4, pp.409-419, 2010. ,
DOI : 10.1016/j.comcom.2009.11.010
Towards an Optimal Positioning of Multiple Mobile Sinks in WSNs for Buildings, International Journal On Advances in Intelligent Systems IARIA, vol.2, issue.4, pp.411-421, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00563717
Sinks Mobility Strategy in IPv6- based WSNs for Network Lifetime Improvement, IFIP International Conference on New Technologies, Mobility and Security NTMS, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00563724
Practical data compression in wireless sensor networks: A survey, Journal of Network and Computer Applications, vol.35, issue.1, 2011. ,
DOI : 10.1016/j.jnca.2011.03.001
Collaborative broadcasting and compression in cluster-based wireless sensor networks, ACM Transactions on Sensor Networks, vol.3, issue.3, 2007. ,
DOI : 10.1145/1267060.1267065
On Maximizing Lifetime of a Sensor Cluster, Sixth IEEE International Symposium on a World of Wireless Mobile and Multimedia Networks, pp.312-317, 2005. ,
DOI : 10.1109/WOWMOM.2005.69
Distributed Data Aggregation Using Clustered Slepian-Wolf Coding in Wireless Sensor Networks, 2007 IEEE International Conference on Communications, pp.3616-3622, 2007. ,
DOI : 10.1109/ICC.2007.596
Impact of correlation in node locations on the performance of distributed compression, 2009 Sixth International Conference on Wireless On-Demand Network Systems and Services, pp.125-132, 2009. ,
DOI : 10.1109/WONS.2009.4801853
TCP/IP compression for low-speed serial links, 1990. ,
RObust Header Compression (ROHC): Corrections and Clarifications to RFC 3095, Transmission of IPv6 Packets over IEEE 802.15.4 Networks, 2007. ,
DOI : 10.17487/rfc4815
Stateless IPv6 Header Compression for Globally Routable Packets in 6LoWPAN Subnetworks, 2007. ,
Compression Format for IPv6 Datagrams in 6LoWPAN Networks, 2010. ,
Dynamic Huffman addressing in wireless sensor networks based on the energy map, MILCOM 2008, 2008 IEEE Military Communications Conference, pp.1-6, 2008. ,
DOI : 10.1109/MILCOM.2008.4753639
Energyefficient communication protocol for wireless microsensor networks, Proceedings of the 33rd Hawaii International Conference on System Sciences, ser. HICSS '00, p.8020, 2000. ,
An application-specific protocol architecture for wireless microsensor networks, IEEE Transactions on Wireless Communications, vol.1, issue.4, pp.660-670, 2002. ,
DOI : 10.1109/TWC.2002.804190
Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, issue.4, pp.471-480, 1973. ,
DOI : 10.1109/TIT.1973.1055037
Distributed source coding using syndromes (DISCUS): design and construction, IEEE Transactions on Information Theory, vol.49, issue.3, pp.626-643, 2003. ,
DOI : 10.1109/TIT.2002.808103
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.27.7164
Recent results in the Shannon theory, IEEE Transactions on Information Theory, vol.20, issue.1, pp.2-10, 1974. ,
DOI : 10.1109/TIT.1974.1055171
On the application of source-coding to addresses transmission, 2011. ,
The Theory of Error-Correcting Codes, twelth impression ed, 2006. ,
Bounding the lifetime of sensor networks via optimal role assignments, Proceedings.Twenty-First Annual Joint Conference of the IEEE Computer and Communications Societies, pp.1587-1596, 2002. ,
DOI : 10.1109/INFCOM.2002.1019410
