Apprentissage discriminant des GMM à grande marge pour la vérification automatique du locuteur - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gaussian mixture models (GMM) have been widely and successfully used in speaker recognition during the last decades. They are generally trained using the generative criterion of maximum likelihood estimation. In an earlier work, we proposed an algorithm for discriminative training of GMM with diagonal covariances under a large margin criterion. In this paper, we present a new version of this algorithm which has the major advantage of being computationally highly efficient. The resulting algorithm is thus well suited to handle large scale databases. To show the effectiveness of the new algorithm, we carry out a full NIST speaker verification task using NIST-SRE'2006 data. The results show that our system outperforms the baseline GMM, and with high computational efficiency.
GRETSI-2011.pdf (68.55 Ko) Télécharger le fichier
hal-00647978 , version 1 (04-12-2011)
  • HAL Id : hal-00647978 , version 1
Reda Jourani, Khalid Daoudi, Régine André-Obrecht, Driss Aboutajdine. Apprentissage discriminant des GMM à grande marge pour la vérification automatique du locuteur. GRETSI, Sep 2011, Bordeaux, France. ⟨hal-00647978⟩
188 Consultations
453 Téléchargements
