Output-sensitive construction of polytopes in four 710 dimensions and clipped Voronoi diagrams in three, 711 Proceedings of the sixth annual ACM-SIAM symposium 712 on Discrete algorithms (SODA), pp.282-291, 1995. ,
On cen- 715 troidal Voronoi tessellation: Energy smoothness and 716 fast computationAr- 717 ticle, ACM Trans. on Graphics, vol.28, issue.4 101, p.718, 2009. ,
Isotropic remeshing with fast 720 and exact computation of restricted Voronoi diagram. 721 Computer Graphics Forum (Proceedings of SGP, pp.722-281445, 2009. ,
Voronoi diagrams---a survey of a fundamental geometric data structure, ACM Computing Surveys, vol.23, issue.3, pp.345-405, 1991. ,
DOI : 10.1145/116873.116880
Semi-structured mesh generation based 799 on medial axis, Proceedings of the 9th International ,
What is a good linear element? inter- 802 polation, conditioning, and quality measures 806 Simplification and improvement of tetrahedral models 807 for simulation, Pro- 803 ceedings of the 11th International Meshing Roundtable Proceedings of the Eurographics Sym- 808 posium on Geometry Processing, pp.21-32, 2000. ,
An 810 algorithm for tetrahedral mesh generation based on con- 811 forming constrained Delaunay tetrahedralization. Com- 812 puters & Graphics Optimal Delaunay triangulations, and Mathieu Desbrun. Variational tetrahedral meshing. 818 ACM Transactions on Graphics (Proceedings of ACM 819 SIGGRAPH 2005), pp.606-615, 2005. ,
Interleaving Delaunay refinement 822 and optimization for practical isotropic tetrahedron 823 mesh generation Burais, and 826 R. Prost. Variational tetraedral mesh generation from 827 discrete volume data. The Visual Computer (Proceed- 828 ings of CGI Cen- 830 troidal Voronoi tessellations: applications and algo- 831 rithms, Proc. SIG- 824 GRAPH) Kazuo Murota, and Takao Ohya. A fast 833, pp.825401-410, 1999. ,
Reen- 838 trant polygon clipping, Communications of the ACM, vol.839, issue.1, pp.1732-1774, 1974. ,
Per- 841 turbing slivers in 3D Delaunay meshes TetGen: A quality tetrahedral mesh gen- 845 erator and three-dimensional Delaunay triangulator, Proceedings 842 of the 18th International Meshing Roundtable, pp.157-173, 2009. ,
FPG: A code gen- 848 erator for fast and certified geometric predicates, Real 849 Numbers and Computers (RNC), pp.47-60, 2008. ,
On the shape of tetra- 851 hedra from bisection. mathematics of computation, 40] P. Cignoni, C. Rocchini, and R. Scopigno. Metro: Mea- 854 suring error on simplified surfaces, pp.63141-154, 1994. ,
