Sparse and structured decompositions of audio signals in overcomplete spaces, Proc. Int'l Conference on Digital Audio Effects (DAFx), pp.22-26, 2004. ,
Sparse Regression with Structured Priors: Application to Audio Denoising, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.174-185, 2008. ,
DOI : 10.1109/ICASSP.2006.1660589
Restoration of blurred star field images by maximally sparse optimization, IEEE Transactions on Image Processing, vol.2, issue.2, pp.202-211, 1993. ,
DOI : 10.1109/83.217223
Low rate and scalable image coding with redundant representations, Tech. Rep, 2003. ,
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
DOI : 10.1109/TIT.2006.871582
URL : https://hal.archives-ouvertes.fr/inria-00369486
Sparse Approximate Solutions to Linear Systems, SIAM Journal on Computing, vol.24, issue.2, pp.227-234, 1995. ,
DOI : 10.1137/S0097539792240406
Subset selection in regression, 2002. ,
Least angle regression, The Annals of Statistics, vol.32, issue.2, p.407499, 2004. ,
The optimization of a quadratic function subject to linear constraints, Naval Research Logistics Quarterly, vol.3, issue.1-2, pp.111-133, 1956. ,
DOI : 10.1002/nav.3800030110
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1998. ,
DOI : 10.1137/S1064827596304010
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society, vol.58, pp.267-288, 1996. ,
Sparse signal reconstruction from limited data using FOCUSS: a re-weighted minimum norm algorithm, IEEE Transactions on Signal Processing, vol.45, issue.3, pp.600-616, 1997. ,
DOI : 10.1109/78.558475
Overcomplete image coding using iterative projection-based noise shaping, Proc. IEEE Int'l Conference on Image Processing (ICIP), pp.597-600, 2002. ,
Iterative Thresholding for Sparse Approximations, Journal of Fourier Analysis and Applications, vol.73, issue.10, pp.629-654, 2008. ,
DOI : 10.1007/s00041-008-9035-z
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
DOI : 10.1109/78.258082
Orthogonal matching pursuit: recursive function approximation with applications to wavelet decomposition, Proceedings of 27th Asilomar Conference on Signals, Systems and Computers, pp.40-44, 1993. ,
DOI : 10.1109/ACSSC.1993.342465
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.348.5735
Adaptive transform coding via quadtree-based variable blocksize DCT, International Conference on Acoustics, Speech, and Signal Processing, pp.23-26, 1989. ,
DOI : 10.1109/ICASSP.1989.266814
Sparse Solution of Underdetermined Systems of Linear Equations by Stagewise Orthogonal Matching Pursuit, IEEE Transactions on Information Theory, vol.58, issue.2, 2006. ,
DOI : 10.1109/TIT.2011.2173241
Subspace Pursuit for Compressive Sensing Signal Reconstruction, IEEE Transactions on Information Theory, vol.55, issue.5, pp.2230-2249, 2009. ,
DOI : 10.1109/TIT.2009.2016006
URL : http://arxiv.org/abs/0803.0811
CoSaMP, Communications of the ACM, vol.53, issue.12, pp.301-321, 2009. ,
DOI : 10.1145/1859204.1859229
Sparse coding with an overcomplete basis set: A strategy employed by V1?, Vision Research, vol.37, issue.23, pp.3311-3325, 1997. ,
DOI : 10.1016/S0042-6989(97)00169-7
Learning Overcomplete Representations, Neural Computation, vol.33, issue.2, pp.337-365, 2000. ,
DOI : 10.1109/18.119725
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.164.7690
A Variational Method for Learning Sparse and Overcomplete Representations, Neural Computation, vol.22, issue.10, pp.2517-2532, 2003. ,
A Bayesian Approach for Blind Separation of Sparse Sources, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.6, pp.2174-2188, 2006. ,
DOI : 10.1109/TSA.2005.858523
Blind separation of sparse sources using jeffrey's inverse prior and the expectationmaximization algorithm, Proc. Int'l Conference on Independent Component Analysis and Blind Source Separation (ICA), pp.593-600, 2006. ,
Fast bayesian matching pursuit, 2008 Information Theory and Applications Workshop, pp.326-333, 2008. ,
DOI : 10.1109/ITA.2008.4601068
Bayesian Pursuit algorithm for sparse representation, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, 2009. ,
DOI : 10.1109/ICASSP.2009.4959892
URL : https://hal.archives-ouvertes.fr/hal-00400478
An Iterative Bayesian Algorithm for Sparse Component Analysis in Presence of Noise, IEEE Transactions on Signal Processing, vol.57, issue.11, pp.4378-4390, 2009. ,
DOI : 10.1109/TSP.2009.2025154
URL : https://hal.archives-ouvertes.fr/hal-00428706
Bayesian Compressive Sensing Via Belief Propagation, IEEE Transactions on Signal Processing, vol.58, issue.1, 2009. ,
DOI : 10.1109/TSP.2009.2027773
URL : http://arxiv.org/abs/0812.4627
Sparse representation algorithms based on mean-field approximations, 2010 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.2034-2037, 2010. ,
DOI : 10.1109/ICASSP.2010.5494965
URL : https://hal.archives-ouvertes.fr/inria-00589354
Bayesian pursuit algorithms, Proc. European Signal Processing Conference (EUSIPCO), 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00673801
From Bernoulli–Gaussian Deconvolution to Sparse Signal Restoration, IEEE Transactions on Signal Processing, vol.59, issue.10, 2010. ,
DOI : 10.1109/TSP.2011.2160633
Enhanced sampling schemes for MCMC based blind Bernoulli???Gaussian deconvolution, Signal Processing, pp.759-772, 2011. ,
DOI : 10.1016/j.sigpro.2010.08.009
URL : https://hal.archives-ouvertes.fr/hal-00517861
Statistical-Physics-Based Reconstruction in Compressed Sensing, Physical Review X, vol.2, issue.2, 2011. ,
DOI : 10.1103/PhysRevX.2.021005
URL : https://hal.archives-ouvertes.fr/hal-00716897
Expectation-maximization Bernoulli-Gaussian approximate message passing, 2011 Conference Record of the Forty Fifth Asilomar Conference on Signals, Systems and Computers (ASILOMAR), 2011. ,
DOI : 10.1109/ACSSC.2011.6190117
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.4327
Robust Recovery of Signals From a Structured Union of Subspaces, IEEE Transactions on Information Theory, vol.55, issue.11, pp.5302-5316, 2009. ,
DOI : 10.1109/TIT.2009.2030471
Compressed sensing of block-sparse signals: uncertainty relations and efficient recovery, 2010. ,
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
Compressive sensing for cluster structured sparse signals: variational Bayes approach, IET Signal Processing, vol.10, issue.7, 2011. ,
DOI : 10.1049/iet-spr.2014.0157
URL : https://hal.archives-ouvertes.fr/hal-00573953
Bayesian Compressive Sensing for clustered sparse signals, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3948-3951, 2011. ,
DOI : 10.1109/ICASSP.2011.5947216
URL : https://hal.archives-ouvertes.fr/hal-00573954
Learning with structured sparsity, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553429
Hybrid generalized approximate message passing with applications to structured sparsity, 2012 IEEE International Symposium on Information Theory Proceedings, 2011. ,
DOI : 10.1109/ISIT.2012.6283054
Message passing algorithms for compressed sensing: I. motivation and construction, IEEE Information Theory Workshop 2010 (ITW 2010), pp.1-5, 2010. ,
DOI : 10.1109/ITWKSPS.2010.5503193
Collaborative hierarchical sparse modeling, 2010 44th Annual Conference on Information Sciences and Systems (CISS), 2010. ,
DOI : 10.1109/CISS.2010.5464845
Sparsity and persistence: mixed norms provide simple signal models with dependent coefficients, Signal, image and video processing, pp.251-264, 2009. ,
DOI : 10.1007/s11760-008-0076-1
URL : https://hal.archives-ouvertes.fr/hal-00206245
Sparse and structured decompositions of signals with the molecular matching pursuit, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.5, pp.1808-1816, 2006. ,
DOI : 10.1109/TSA.2005.858540
URL : https://hal.archives-ouvertes.fr/hal-00105054
Proximal methods for hierarchical sparse coding, Tech. Rep, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00516723
Exploiting structure in wavelet-based bayesian compressive sensing, IEEE Trans. On Signal Processing, vol.57, issue.9, pp.3488-3497, 2009. ,
Tree-structured compressive sensing with variational bayesian analysis, IEEE Signal Processing Letters, vol.17, issue.3, pp.233-236, 2010. ,
Turbo reconstruction of structured sparse signals, 2010 44th Annual Conference on Information Sciences and Systems (CISS), pp.1-6, 2010. ,
DOI : 10.1109/CISS.2010.5464920
Learning horizontal connections in a sparse coding model of natural images, Advances in Neural Information Processing Systems (NIPS), pp.505-512, 2008. ,
Sparse signal recovery using markov random fields, Advances in Neural Information Processing Systems (NIPS), 2008. ,
Exploiting statistical dependencies in sparse representations for signal recovery ,
Model-Based Compressive Sensing, IEEE Transactions on Information Theory, vol.56, issue.4, pp.1982-2001, 2010. ,
DOI : 10.1109/TIT.2010.2040894
A Learning Algorithm for Boltzmann Machines*, Cognitive Science, vol.85, issue.1, pp.147-169, 1985. ,
DOI : 10.1207/s15516709cog0901_7
Principles of Signal Detection and Parameter Estimation, 2008. ,
Graphical Models, Exponential Families, and Variational Inference, Foundations and Trends?? in Machine Learning, vol.1, issue.1???2, 2003. ,
DOI : 10.1561/2200000001
Variational algorithms for approximate Bayesian inference, 2003. ,
Using lower bounds to approximate integrals, 2001. ,
The variational bayesian em algorithm for incomplete data: with application to scoring graphical model structures, Bayesian Statistics, vol.7, pp.453-463, 2003. ,
Maximum likelihood from incomplete data via the em algorithm, Journal of the Royal Statistical Society. Series B (Methodological), vol.39, pp.1-38, 1977. ,
A View of the Em Algorithm that Justifies Incremental, Sparse, and other Variants, Learning in graphical models, pp.355-368, 1998. ,
DOI : 10.1007/978-94-011-5014-9_12
Soft Bayesian pursuit algorithm for sparse representations, 2011 IEEE Statistical Signal Processing Workshop (SSP), pp.341-344, 2011. ,
DOI : 10.1109/SSP.2011.5967699
Sparse component analysis in presence of noise using em-map, Proc ,
URL : https://hal.archives-ouvertes.fr/hal-00173379
on Independent Component Analysis and Signal Separation, 2007. ,
Mcmc for doubly-intractable distributions, Proc. Annual Conference on Uncertainty in Artificial Intelligence (UAI), pp.359-366, 2006. ,
Efficient learning in sparsely connected Boltzmann machines, Proc. Int'l Conf. on Artificial Neural Networks, 1996. ,
DOI : 10.1007/3-540-61510-5_11
Mixture representations for inference and learning in boltzmann machines, Proc. Conference on Uncertainty in Artificial Intelligence, 1998. ,
Generalized approximate message passing for estimation with random linear mixing, 2011 IEEE International Symposium on Information Theory Proceedings, 2010. ,
DOI : 10.1109/ISIT.2011.6033942
