The MHAOTEU Toolset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The MHAOTEU Toolset
Sid Touati
  • Fonction : Auteur
  • PersonId : 962200
Alan Anderson
  • Fonction : Auteur
  • PersonId : 915280
Christine Eisenbeis
  • Fonction : Auteur
  • PersonId : 833430
Grigori Fursin
  • Fonction : Auteur
  • PersonId : 832076
Olivier Temam
  • Fonction : Auteur
  • PersonId : 830062
Memory latency is one of the main reasons for performance degradation of current computers. This problem is exacerbated by the fact that the relative memory latency increases by about 50% per year. On the other hand, there is a lack of tools to help programmers to improve their applications from a memory perspective. This paper presents the MHAOTEU toolset, a set of tools that are build to help the programmers to tune their applications for a better use of the memory hierarchy.
Autre [cs.OH]
The_MHAOTEU.pdf (167.18 Ko) Télécharger le fichier
hal-00648211 , version 1 (05-12-2011)
  • HAL Id : hal-00648211 , version 1
Jaume Abella, Sid Touati, Alan Anderson, Carlos Ciuraneta, Josep M. Codina, et al.. The MHAOTEU Toolset. 16th IMACS world congress 2000 on scientific computation, applied mathematics and simulation (IMACS'2000), Ecole polytechnique fédérale de Lausanne, Aug 2000, Lausanne, Switzerland. pp.6. ⟨hal-00648211⟩
353 Consultations
82 Téléchargements
