The Time Dependent Traveling Salesman Problem: Polyhedra and Branch-Cut-and-Price Algorithm, Lecture Notes in Computer Science, vol.6049, pp.202-213, 2010. ,
DOI : 10.1007/978-3-642-13193-6_18
The traveling salesman problem with cumulative costs, Networks, vol.26, issue.2, pp.81-91, 1993. ,
DOI : 10.1002/net.3230230202
The time-dependent traveling salesman problem and single machine scheduling problems with sequence dependent setup times, Discrete Optimization, vol.5, issue.4, pp.685-699, 2008. ,
DOI : 10.1016/j.disopt.2008.04.001
A New Formulation for the Travelling Salesman Problem, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.1, pp.21-26, 1984. ,
DOI : 10.1137/0605004
Models and branch-and-cut algorithms for the Steiner tree problem with revenues, budget and hop constraints, Networks, vol.86, issue.2, pp.141-159, 2009. ,
DOI : 10.1002/j.1538-7305.1957.tb01515.x
The Delivery Man Problem and Cumulative Matroids, Operations Research, vol.41, issue.6, 1055. ,
DOI : 10.1287/opre.41.6.1055
Graves 'A N-Constrained formulation of the (Time-dependent) ,
Combined route capacity and route length models for unit demand vehicle routing problems, Discrete Optimization, vol.5, issue.2, pp.350-372, 2008. ,
DOI : 10.1016/j.disopt.2007.05.001
On Time-Dependent Models for Unit Demand Vehicle Routing Problems, Proceedings of the INOC2007 Conference, 2007. ,
Formulations for the ATSP: contextualizing a strong time dependent flow based formulation ,
Using Hop-Indexed Models For Constrained Spanning and Steiner Tree Models, Telecommunications Network Planning, pp.21-32, 1999. ,
DOI : 10.1007/978-1-4615-5087-7_2
On extended formulations for the precedence constrained asymmetric traveling salesman problem, Networks, vol.22, issue.2, pp.77-89, 2006. ,
DOI : 10.1002/net.20122
URL : https://hal.archives-ouvertes.fr/inria-00281586
Uma análise comparativa de formulações para o Problema do Caixeiro Viajante, Investigação Operacional, vol.16, pp.89-114, 1996. ,
The asymmetric travelling salesman problem: on generalizations of disaggregated Miller???Tucker???Zemlin constraints, Discrete Applied Mathematics, vol.112, issue.1-3, pp.1-3, 2001. ,
DOI : 10.1016/S0166-218X(00)00313-9
Modelling Hop-Constrained and Diameter-Constrained Minimum Spanning Tree Problems as Steiner Tree Problems over Layered Graphs, Mathematical Programming, 2009. ,
A classification of formulations for the (time-dependent) traveling salesman problem, European Journal of Operational Research, vol.83, issue.1, pp.69-82, 1995. ,
DOI : 10.1016/0377-2217(93)E0238-S
Classification of travelling salesman problem formulations, Operations Research Letters, vol.9, issue.2, pp.127-132, 1990. ,
DOI : 10.1016/0167-6377(90)90052-7
The Traveling Salesman Problem: A Guided Tour of Combinatorial Optimization., The Journal of the Operational Research Society, vol.37, issue.5, 1985. ,
DOI : 10.2307/2582681
Integer Programming Formulation of Traveling Salesman Problems, Journal of the ACM, vol.7, issue.4, pp.326-329, 1960. ,
DOI : 10.1145/321043.321046
Time-dependent traveling salesman problem???the deliveryman case, Networks, vol.26, issue.6, pp.753-763, 1990. ,
DOI : 10.1002/net.3230200605
A new formulation for the Traveling Deliveryman Problem, Discrete Applied Mathematics, vol.156, issue.17, pp.3223-3237, 2008. ,
DOI : 10.1016/j.dam.2008.05.009
A comparative analysis of several asymmetric traveling salesman problem formulations, Computers & Operations Research, vol.36, issue.3, pp.637-654, 2009. ,
DOI : 10.1016/j.cor.2007.11.008
The Time-Dependent Traveling Salesman Problem and Its Application to the Tardiness Problem in One-Machine Scheduling, Operations Research, vol.26, issue.1, pp.86-110, 1978. ,
DOI : 10.1287/opre.26.1.86
New tighter polynomial length formulations for the asymmetric traveling salesman problem with and without precedence constraints, Operations Research Letters, vol.33, issue.1, pp.62-70, 2005. ,
DOI : 10.1016/j.orl.2004.03.007
On Tightening the Relaxations of Miller-Tucker-Zemlin Formulations for Asymmetric Traveling Salesman Problems, Operations Research, vol.50, issue.4, pp.656-669, 2002. ,
DOI : 10.1287/opre.50.4.656.2865
A class of lifted path and flow-based formulations for the asymmetric traveling salesman problem with and without precedence constraints, Discrete Optimization, vol.3, issue.1, pp.20-32, 2006. ,
DOI : 10.1016/j.disopt.2005.10.004
Approximate extended formulations, Mathematical Programming, vol.48, issue.2-3, pp.501-522, 2006. ,
Integer programming formulations of the traveling salesman problem, Proceedings of the IEEE international conference of circuits and computers, pp.149-52, 1980. ,
