Toward Direct Data Assimilation of Image Sequences in Numerical Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A large number of satellites provide a significant amount of photographs of the earth. Attempt to perform Image Assimilation have been done using pseudo-observation techniques: they provide some apparent velocity fields, which are assimilated as classical Eulerian velocity observations. However these measurements are obtained by procedures that are decoupled with the system. Here, we suggest a more consistent approach where image sequences are directly incorporated into the Optimality System in a Variational Data assimilation framework.
Fichier non déposé
hal-00648562 , version 1 (06-12-2011)
  • HAL Id : hal-00648562 , version 1
Arthur Vidard, Innocent Souopgui, Olivier Titaud, François-Xavier Le Dimet. Toward Direct Data Assimilation of Image Sequences in Numerical Models. ICIAM2011 - 8th International Congress on Industrial & Applied Mathematics, Jul 2011, Vancouver, Canada. ⟨hal-00648562⟩
165 Consultations
0 Téléchargements
