AGROCAMPUS OUEST (Institut Supérieur des Sciences Agronomiques, Agroalimentaires, Horticoles et du Paysage - 65, rue de St Brieuc - CS 84215 - 35042 Rennes cedex - France)
Abstract : In this paper, we study a robust control problem for a class of systems governed by nonlinear parabolic equations. Firstly the control is the forcing. We formulate the robust control problem, we prove the existence and the uniqueness of the solution and we give the necessary conditions of optimality. Secondly an initial perturbation problem is considered. A robust control problem is reformulated and the existence and the conditions of the uniqueness of the optimal solution are derived. First order necessary conditions of optimality are obtained.
https://hal.archives-ouvertes.fr/hal-00648883
Contributeur : Aziz Belmiloudi <>
Soumis le : mardi 6 décembre 2011 - 15:22:31
Dernière modification le : mercredi 12 juillet 2017 - 01:16:58
Aziz Belmiloudi. ON SOME ROBUST CONTROL PROBLEMS FOR NONLINEAR PARABOLIC EQUATIONS. International Journal of Pure and Applied Mathematics, Academic Publishing Ltd, 2004, Volume 11 (Issue 2), pp.119-149. <hal-00648883>
