Comment on ???Diffusion theory for transport in porous media: Transition-probability densities of diffusion processes corresponding to advection-dispersion equations??? by Eric M. LaBolle et al., Water Resources Research, vol.146, issue.10, pp.819-821, 2000. ,
DOI : 10.1029/1999WR900326
Solute transport across an interface: A Fickian theory for skewness in breakthrough curves Occupation and local times for Skew Brownian motion with application to dispersion accross an interface, W07511, DOI 10.1029, pp.183-21410, 1214. ,
Exact Asymptotics for the Probability of Exit from a Domain and Applications to Simulation, The Annals of Probability, vol.23, issue.4, pp.1644-1670, 1995. ,
DOI : 10.1214/aop/1176987797
Efficient random walk particle tracking algorithm for advective-dispersive transport in media with discontinuous dispersion coefficients and water contents, Water Resources Research, vol.45, issue.10, pp.47-10526, 2011. ,
DOI : 10.1029/2010WR010267
A simple and efficient random walk solution of multi-rate mobile/immobile mass transport equations, Advances in Water Resources, vol.32, issue.4, pp.532-539, 2009. ,
DOI : 10.1016/j.advwatres.2009.01.002
Laboratory experiments on dispersive transport across interfaces: The role of flow direction, Water Resources Research, vol.49, issue.4, 2009. ,
DOI : 10.1029/2008WR007342
Exact simulation of diffusions, The Annals of Applied Probability, vol.15, issue.4, pp.2422-2444, 2005. ,
DOI : 10.1214/105051605000000485
Probabilistic interpretation and random walk on spheres algorithms for the Poisson-Boltzmann equation in molecular dynamics, ESAIM: Mathematical Modelling and Numerical Analysis, vol.44, issue.5, pp.44-997, 2010. ,
DOI : 10.1051/m2an/2010050
URL : https://hal.archives-ouvertes.fr/inria-00459411
Simulation of stopped diffusions, Journal of Computational Physics, vol.202, issue.2, pp.446-462, 2005. ,
DOI : 10.1016/j.jcp.2004.07.009
Model of dispersive transport across sharp interfaces between porous materials, Physical Review E, vol.80, issue.1, p.11122, 2009. ,
DOI : 10.1103/PhysRevE.80.011122
A Monte Carlo method without grid for a fractured porous domain model, Monte Carlo Methods Appl, pp.129-148, 2002. ,
Diffusion Models for Population Dynamics Incorporating Individual Behavior at Boundaries: Applications to Refuge Design, Theoretical Population Biology, vol.55, issue.2, pp.189-207, 1999. ,
DOI : 10.1006/tpbi.1998.1397
Hitting time for Bessel processes ? walk on moving spheres algorithm (2011), available at arxiv::1111.3736 ,
A Random Walk on Rectangles Algorithm, Methodology and Computing in Applied Probability, vol.24, issue.2, pp.135-151, 2006. ,
DOI : 10.1007/s11009-006-7292-3
URL : https://hal.archives-ouvertes.fr/inria-00092424
SELF EXCITING THRESHOLD INTEREST RATES MODELS, International Journal of Theoretical and Applied Finance, vol.09, issue.07, pp.1093-1122, 2006. ,
DOI : 10.1142/S0219024906003937
Simulating Solute Transport in Porous or Fractured Formations Using Random Walk Particle Tracking, Vadose Zone Journal, vol.4, issue.2, pp.360-379, 2005. ,
DOI : 10.2136/vzj2004.0125
Non-Uniform Random Variate Generation, 1986. ,
DOI : 10.1007/978-1-4613-8643-8
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.333.8896
On random walk simulation of one-dimensional diffusion processes with discontinuous coefficients, Electron, J. Probab, vol.11, issue.9, pp.249-275, 2006. ,
A Donsker theorem to simulate one-dimensional processes with measurable coefficients, ESAIM Probab, Stat, vol.11, pp.301-326, 2007. ,
Exact simulation of one-dimensional stochastic differential equations involving the local time at zero of the unknown process, 2011. ,
Monte Carlo study of a two-compartment exchange model of diffusion, NMR in Biomedicine, vol.436, issue.7, pp.711-724, 2010. ,
DOI : 10.1002/nbm.1577
Weak approximation of killed diffusion using Euler schemes, Stochastic Process, Appl, vol.87, issue.299, pp.167-197, 2000. ,
Stopped diffusion processes: boundary corrections and overshoot, Stochastic Process, Appl, vol.120, issue.2, pp.130-162, 2010. ,
DOI : 10.1016/j.spa.2009.09.014
URL : http://doi.org/10.1016/j.spa.2009.09.014
Multiple-Rate Mass Transfer for Modeling Diffusion and Surface Reactions in Media with Pore-Scale Heterogeneity, Water Resources Research, vol.24, issue.8, pp.2383-2400, 1995. ,
DOI : 10.1029/95WR10583
On Skew Brownian Motion, The Annals of Probability, vol.9, issue.2, pp.309-313, 1981. ,
DOI : 10.1214/aop/1176994472
Ackerer, Three-dimensional modeling of mass transfer in porous media using the mixed hybrid finite elements and the random-walk methods, Mathematical Geology, vol.34, issue.4, pp.435-456, 2002. ,
DOI : 10.1023/A:1015083111971
Diffusion processes and their sample paths, 1974. ,
Exponential Timestepping with Boundary Test for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.5, pp.1809-1822, 2003. ,
DOI : 10.1137/S1064827501399535
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.5540
Brownian motion and stochastic calculus, Graduate Texts in Mathematics, vol.113, 1991. ,
Random-Walk Simulation of Transport in Heterogeneous Porous Media: Local Mass-Conservation Problem and Implementation Methods, Water Resources Research, vol.224, issue.10, pp.582-593, 1996. ,
DOI : 10.1029/95WR03528
Reply to comment by D.-H. Lim on ???Diffusion processes in composite porous media and their numerical integration by random walks: Generalized stochastic differential equations with discontinuous coefficients???, W02602, DOI 10, 1029. ,
DOI : 10.1029/2005WR004403
Diffusion processes in composite porous media and their numerical integration by random walks: Generalized stochastic differential equations with discontinuous coefficients, Water Resources Research, vol.146, issue.10, pp.651-662, 2000. ,
DOI : 10.1029/1999WR900224
Simulation of a stochastic process in a discontinuous layered medium, Electronic Communications in Probability, vol.16, issue.0, pp.764-774, 2011. ,
DOI : 10.1214/ECP.v16-1686
Ural ceva, Solvability of diffraction problems in the classical sense, Trudy Mat. Inst. Steklov, vol.92, pp.116-146, 1966. ,
exitbm: a library for simulating exit times and positions for the Brownian motion from simple domains Description of a C library, 2011. ,
A scheme for simulating one-dimensional diffusion processes with discontinuous coefficients, The Annals of Applied Probability, vol.16, issue.1, pp.107-139, 2006. ,
DOI : 10.1214/105051605000000656
URL : https://hal.archives-ouvertes.fr/inria-00000410
Approximate exit probabilities for a Brownian bridge on a short time interval, and applications, Advances in Applied Probability, vol.39, issue.01, pp.1-19, 1989. ,
DOI : 10.1214/aop/1176993768
Comment on Diffusion processes in composite porous media and their numerical integration by random walks: Generalized stochastic differential equations with discontinuous coefficients, W02601, DOI 10, 1029. ,
Postshock turbulence and diffusive shock acceleration in young supernova remnants, Astronomy and Astrophysics, vol.515, pp.4-6361, 2010. ,
DOI : 10.1051/0004-6361/200913022
URL : https://hal.archives-ouvertes.fr/hal-00447523
Normal and anomalous transport across an interface: Monte Carlo and analytical approach, Annals of Nuclear Energy, vol.33, issue.17-18, pp.1396-1407, 2006. ,
DOI : 10.1016/j.anucene.2006.09.012
URL : http://arxiv.org/abs/0706.2095
Interprétations probabilistes d'opérateurs sous forme divergence et analyse de méthodes numériques associées, 2004. ,
Discr??tisation d'??quations diff??rentielles stochastiques unidimensionnelles ?? g??n??rateur sous forme divergence avec coefficient discontinu, Dimensional parabolic diffraction equations: Pointwise estimates and discretization of related stochastic differential equations with weighted local times, pp.51-56, 2006. ,
DOI : 10.1016/j.crma.2005.10.025
Monte Carlo Methods for Calculating Some Physical Properties of Large Molecules, SIAM Journal on Scientific Computing, vol.26, issue.1, pp.339-357, 2004. ,
DOI : 10.1137/S1064827503422221
The restaurant at the end of the random walk: recent developments in the description of anomalous transport by fractional dynamics, Journal of Physics A: Mathematical and General, vol.37, issue.31, pp.161-208, 2004. ,
DOI : 10.1088/0305-4470/37/31/R01
Generating Random Variates Using Transformations with Multiple Roots, The American Statistician, vol.29, issue.2, pp.88-90, 1976. ,
DOI : 10.1080/01621459.1968.10480942
Simulation of a space-time bounded diffusion, The Annals of Applied Probability, vol.9, issue.3, pp.732-779, 1999. ,
DOI : 10.1214/aoap/1029962812
Random Walks on Lattices. II, Journal of Mathematical Physics, vol.6, issue.2, pp.167-181, 1965. ,
DOI : 10.1063/1.1704269
Biased movement at a boundary and conditional occupancy times for diffusion processes, Journal of Applied Probability, vol.52, issue.53, pp.557-580, 2003. ,
Skew Brownian Motion and Branching Processes Applied to Diffusion- Advection in Heterogenous Media and Fluid Flow, 2007. ,
A Generalized Taylor???Aris Formula and Skew Diffusion, Multiscale Modeling & Simulation, vol.5, issue.3, pp.786-801, 2006. ,
DOI : 10.1137/050642770
A note on the theoretical foundations of particle tracking methods in heterogeneous porous media, W01501, DOI 10, 1029. ,
DOI : 10.1029/2007WR005914
A review and numerical assessment of the random walk particle tracking method, Journal of Contaminant Hydrology, vol.87, issue.3-4, pp.277-305, 2006. ,
DOI : 10.1016/j.jconhyd.2006.05.005
Gómez-Hernández, Modeling mass transfer processes using random walk particle tracking, no. W11417, DOI 10, 1029. ,
DOI : 10.1029/2006wr004927
Modélisation tridimensionnel le du transport d'un traceur en milieux poreux saturé: évaluation des théories stochastiques, Thèse de doctorat, 1994. ,
Diffusion semigroups corresponding to uniformly elliptic divergence form operators, Lecture Notes in Math, vol.80, issue.4, pp.316-347, 1988. ,
DOI : 10.2307/2372841
Treatment of Interfaces in Random Walk Dispersion Models, Journal of Applied Meteorology, vol.36, issue.9, pp.1284-1295, 1997. ,
DOI : 10.1175/1520-0450(1997)036<1284:TOIIRW>2.0.CO;2
A random walk method for the simulation of macrodispersion in a stratified aquifer, Relation of Groundwater Quantity and Quality, pp.103-114, 1985. ,
A diffusion with discontinuous local time, Temps locaux, pp.37-45, 1978. ,
Calculation of Diffusive Shock Acceleration of Charged Particles by Skew Brownian Motion, The Astrophysical Journal, vol.541, issue.1, pp.428-435, 2000. ,
DOI : 10.1086/309429
