New interface
Conference papers
Model-Based Security Verification and Testing for Smart-cards
Elizabeta Fourneret 1 Martin Ochoa 2 Fabrice Bouquet 1 Julien Botella 3 Jan Jürjens 2 Parvaneh Yousefi 2
1 CASSIS - Combination of approaches to the security of infinite states systems
FEMTO-ST - Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (UMR 6174), Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : Model-Based Testing (MBT) is a widely used methodology for generating tests aiming to ensure that the system behaviour conforms to its specification. Recently, it has been successfully applied for testing certain security properties. However, for the success of this approach, it is an important prerequisite to consider the correctness of test models with respect to the given security property. In this paper we present an approach for smart-card specific security properties that permits to validate the system with MBT from test schemas. We combine this MBT approach with UMLsec security verification technique, by using UMLsec stereotypes to verify the model w.r.t. given security properties and gain more confidence in the model. We then define an automatic procedure to generate security test from the UMLsec model via so-called "test schemas". We validate this approach on a fragment of the Global Platform specification and report on available tool support.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00649256
Contributor : Fabrice Bouquet Connect in order to contact the contributor
Submitted on : Wednesday, December 7, 2011 - 3:03:28 PM
Last modification on : Friday, January 21, 2022 - 3:09:07 AM
Identifiers
Citation
Elizabeta Fourneret, Martin Ochoa, Fabrice Bouquet, Julien Botella, Jan Jürjens, et al.. Model-Based Security Verification and Testing for Smart-cards. 6th International Conference on Availability, Reliability and Security - ARES 2011, Aug 2011, Vienna, Austria. pp.272 - 279, ⟨10.1109/ARES.2011.46⟩. ⟨hal-00649256⟩
Share
Metrics
Record views
279
