A sparse model predictive control formulation for walking motion generation - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
This article presents a comparison between dense and sparse model predictive control (MPC) formulations, in the context of walking motion generation for humanoid robots. The former formulation leads to smaller, the latter one to larger but more structured optimization problem. We put an accent on the sparse formulation and point out a number of advantages that it presents. In particular, motion generation with variable center of mass (CoM) height, as well as variable discretization of the preview window, come at a negligible additional computational cost. We present a sparse formulation that comprises a diagonal Hessian matrix and has only simple bounds (while still retaining the possibility to generate motions for an omnidirectional walk). Finally, we present the results from a customized code used to solve the underlying quadratic program (QP).
paper_iros11.pdf (218.32 Ko) Télécharger le fichier
Dates and versions
hal-00649279 , version 1 (07-12-2011)
Identifiers
Cite
Dimitar Dimitrov, Alexander Sherikov, Pierre-Brice Wieber. A sparse model predictive control formulation for walking motion generation. IROS 2011 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Sep 2011, San Francisco, United States. pp.2292-2299, ⟨10.1109/IROS.2011.6095035⟩. ⟨hal-00649279⟩
342 View
514 Download
Share
