Non-crossing tree realizations of ordered degree sequences
We investigate the enumeration of non-crossing tree realizations of integer sequences, and we consider a special case in four parameters, that can be seen as a four-dimensional tetrahedron that generalizes Pascal's triangle and the Catalan numbers.
