Scikit-learn: Machine Learning in Python
Abstract : Scikit-learn is a Python module integrating a wide range of state-of-the-art machine learning algorithms for medium-scale supervised and unsupervised problems. This package focuses on bringing machine learning to non-specialists using a general-purpose high-level language. Emphasis is put on ease of use, performance, documentation, and API consistency. It has minimal dependencies and is distributed under the simplified BSD license, encouraging its use in both academic and commercial settings. Source code, binaries, and documentation can be downloaded from http://scikit-learn.sourceforge.net.
Complete list of metadatas
https://hal.inria.fr/hal-00650905
Contributor : Fabian Pedregosa <>
Submitted on : Monday, January 2, 2012 - 3:15:18 PM
Last modification on : Tuesday, August 6, 2019 - 11:38:50 AM
Long-term archiving on: Tuesday, April 3, 2012 - 2:20:15 AM
pedregosa11a.pdf
Publisher files allowed on an open archive
Identifiers
  • HAL Id : hal-00650905, version 1
  • ARXIV : 1201.0490
Citation
Fabian Pedregosa, Gaël Varoquaux, Alexandre Gramfort, Vincent Michel, Bertrand Thirion, et al.. Scikit-learn: Machine Learning in Python. Journal of Machine Learning Research, Microtome Publishing, 2011. ⟨hal-00650905v1⟩
Share
Metrics
Record views
344
Files downloads
3880
