New interface
Journal articles
Data assimilation for short-range dispersion of radionuclides : An application to Wind Tunnel Data
Abstract : This work contributes to improvement in consequences evaluation for a release of radioactivity to the atmosphere at local scale. An investigation of how such an improvement could be achieved with the help of variational data assimilation is presented. The measurements collected in a wind tunnel experiment are coupled to a Gaussian puff model. Capacity of finding the true source emission rate is tackled in the first place. Secondly, data assimilation is employed to accommodate the computed concentration profiles to the measured ones. Benefit from data assimilation is subject to the quantity of information contained in the measurements. Therefore, posterior analysis of the monitoring network is carried out and its quality assessed.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00650966
Contributor : Nathalie Gaudechoux Connect in order to contact the contributor
Submitted on : Monday, December 12, 2011 - 3:28:24 PM
Last modification on : Tuesday, November 15, 2022 - 10:58:34 AM
Links full text
Identifiers
Collections
Citation
Monika Krysta, Marc Bocquet, Bruno Sportisse, Olivier Isnard. Data assimilation for short-range dispersion of radionuclides : An application to Wind Tunnel Data. Atmospheric Environment, 2006, 40 (38), pp.7267-7279. ⟨10.1016/j.atmosenv.2006.06.043⟩. ⟨hal-00650966⟩
Share
Metrics
Record views
134
