Abstract : Since the cost of communication (moving data) greatly exceeds the cost of doing arithmetic on current and future computing platforms, we are motivated to devise algorithms that communicate as little as possible, even if they do slightly more arithmetic, and as long as they still get the right answer. This paper is about getting the right answer for such an algorithm. It discusses CALU, a communication avoiding LU factorization algorithm based on a new pivoting strategy, that we refer to as tournament pivoting. The reason to consider CALU is that it does an optimal amount of communication, and asymptotically less than Gaussian elimination with partial pivoting (GEPP), and so will be much faster on platforms where communication is expensive, as shown in previous work. We show that the Schur complement obtained after each step of performing CALU on a matrix A is the same as the Schur complement obtained after performing GEPP on a larger matrix whose entries are the same as the entries of A (sometimes slightly perturbed) and zeros. More generally, the entire CALU process is equivalent to GEPP on a large, but very sparse matrix, formed by entries of A and zeros. Hence we expect that CALU will behave as GEPP and it will also be very stable in practice. In addition, extensive experiments on random matrices and a set of special matrices show that CALU is stable in practice. The upper bound on the growth factor of CALU is worse than that of GEPP. However, there are Wilkinson-like matrices for which GEPP has exponential growth factor, but not CALU, and vice-versa.
