{MLE} for partially observed diffusions: direct maximization vs. the {EM} algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 1989
Fabien Campillo
François Le Gland
  • Fonction : Auteur
  • PersonId : 832228
Two algorithms are compared for maximizing the likelihood function associated with parameter estimation in partially observed diffusion processes: 1) the EM algorithm, an iterative algorithm where, at each iteration, an auxiliary function is computed and maximized; 2) the direct approach where the likelihood function itself is computed and maximized. This yields to a comparison of nonlinear smoothing and nonlinear filtering for computing a class of conditional expectations related to the problem of estimation. It is shown that smoothing is indeed necessary for the EM algorithm approach to be efficient. Time discretization schemes for the stochastic PDÉs involved in the algorithms are given, and the link with the discrete time case (hidden Markov model) is explored.
Fichier non déposé
hal-00652122 , version 1 (14-12-2011)
  • HAL Id : hal-00652122 , version 1
Fabien Campillo, François Le Gland. {MLE} for partially observed diffusions: direct maximization vs. the {EM} algorithm. Stochastic Processes and their Applications, 1989, 33 (2), pp.245--274. ⟨hal-00652122⟩
Collections
INRIA INRIA2
225 Consultations
0 Téléchargements
