New interface
Journal articles
Computation of Ice Shedding Trajectories Using Cartesian Grids, Penalization, and Level Sets
Héloïse Beaugendre 1, 2, 3 François Morency 4 Fédérico Gallizio 5 Sophie Laurens 2, 6
2 MC2 - Modélisation, contrôle et calcul
Inria Bordeaux - Sud-Ouest, UB - Université de Bordeaux, CNRS - Centre National de la Recherche Scientifique : UMR5251
3 BACCHUS - Parallel tools for Numerical Algorithms and Resolution of essentially Hyperbolic problems
Inria Bordeaux - Sud-Ouest, UB - Université de Bordeaux, CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : We propose to model ice shedding trajectories by an innovative paradigm that is based on cartesian grids, penalization and level sets. The use of cartesian grids bypasses the meshing issue, and penalization is an efficient alternative to explicitly impose boundary conditions so that the body-fitted meshes can be avoided, making multifluid/multiphysics flows easy to set up and simulate. Level sets describe the geometry in a nonparametric way so that geometrical and topological changes due to physics and in particular shed ice pieces are straight forward to follow. The model results are verified against the case of a free falling sphere. The capabilities of the proposed model are demonstrated on ice trajectories calculations for flow around iced cylinder and airfoil.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00653224
Contributor : Héloïse Beaugendre Connect in order to contact the contributor
Submitted on : Monday, December 19, 2011 - 10:07:21 AM
Last modification on : Tuesday, October 25, 2022 - 11:58:10 AM
Links full text
Identifiers
Citation
Héloïse Beaugendre, François Morency, Fédérico Gallizio, Sophie Laurens. Computation of Ice Shedding Trajectories Using Cartesian Grids, Penalization, and Level Sets. Modelling and Simulation in Engineering, 2011, 2011, pp.1-15. ⟨10.1155/2011/274947⟩. ⟨hal-00653224⟩
Share
Metrics
Record views
183
