Jointly constrained biconvex programming, Mathematics of Operations Research, vol.8, issue.2, pp.273-286, 1983. ,
Bounded model checking of software using SMT solvers instead of SAT solvers, International Journal on Software Tools for Technology Transfer, vol.31, issue.1, pp.69-83, 2009. ,
DOI : 10.1007/s10009-008-0091-0
Symbolic Model Checking without BDDs, Proceedings of the 5th International Conference on Tools and Algorithms for Construction and Analysis of Systems, TACAS '99, pp.193-207, 1999. ,
DOI : 10.1007/3-540-49059-0_14
Safe and tight linear estimators for global optimization, Mathematical Programming, 2005. ,
DOI : 10.1007/s10107-004-0533-8
Symbolic execution of floating-point computations, Software Testing, Verification and Reliability, vol.14, issue.2, pp.97-121, 2006. ,
DOI : 10.1002/stvr.333
URL : https://hal.archives-ouvertes.fr/inria-00540299
Ansi-c bounded model checker user manual, 2006. ,
CPBPV: a constraint-programming framework for bounded program verification, Constraints, vol.404, issue.3, pp.238-264, 2010. ,
DOI : 10.1007/s10601-009-9089-9
Smt-based bounded model checking for embedded ansi-c software, IEEE Transactions on Software Engineering, 2011. ,
Varieties of static analyzers: A comparison with astree, Proceedings of the First Joint IEEE/IFIP Symposium on Theoretical Aspects of Software Engineering, pp.3-20, 2007. ,
Accelerating high-level bounded model checking, Proceedings of the 2006 IEEE/ACM international conference on Computer-aided design, ICCAD '06, pp.794-801, 2006. ,
A Logical Product Approach to Zonotope Intersection, Computer Aided Verification, pp.212-226, 2010. ,
DOI : 10.1007/978-3-642-14295-6_22
Automatic test data generation using constraint solving techniques, ISSTA, pp.53-62, 1998. ,
A CLP Framework for Computing Structural Test Data, Computational Logic, volume 1861 of Lecture Notes in Computer Science, pp.399-413, 2000. ,
DOI : 10.1007/3-540-44957-4_27
Efficient and Safe Global Constraints for Handling Numerical Constraint Systems, SIAM Journal on Numerical Analysis, vol.42, issue.5 ,
DOI : 10.1137/S0036142903436174
URL : https://hal.archives-ouvertes.fr/hal-00907765
Computability of global solutions to factorable nonconvex programs: Part I ??? Convex underestimating problems, Mathematical Programming, pp.147-175, 1976. ,
DOI : 10.1287/mnsc.17.11.759
Safe embedding of the simplex algorithm in a CSP framework, Proc. of 5th Int. Workshop on Integration of AI and OR techniques in Constraint Programming for Combinatorial Optimisation Problems CPAIOR 2003, pp.210-220, 2003. ,
Exact projection functions for floating point number constraints (pdf), AMAI, 2002. ,
Solving Constraints over Floating-Point Numbers, Lecture Notes in Computer Science, vol.2239, pp.524-538, 2001. ,
DOI : 10.1007/3-540-45578-7_36
Weakly Relational Numerical Abstract Domains, 2004. ,
Safe bounds in linear and mixed-integer linear programming, Mathematical Programming, vol.99, issue.2, pp.99283-296, 2004. ,
DOI : 10.1007/s10107-003-0433-3
IEEE 754-2008, Standard for Floating-Point Arithmetic, 2008. ,
Refining abstract interpretation-based approximations with a floating-point constraint solver, NSV-2011: Fourth International Workshop on Numerical Software Verification, Cliff Lodge, 2011. ,
A branch-and-reduce approach to global optimization, Journal of Global Optimization, pp.107-138, 1996. ,
