State-constrained Optimal Control Problems of Impulsive Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Optimization Année : 2013
The present paper studies an optimal control problem governed by measure driven differential systems and in presence of state constraints. The first result shows that using the graph completion of the measure, the optimal solutions can be obtained by solving a reparametrized control problem of absolutely continuous trajectories but with time-dependent state-constraints. The second result shows that it is possible to characterize the epigraph of the reparametrized value function by a Hamilton-Jacobi equation without assuming any controllability assumption.
Article_BRZ.pdf (198.89 Ko) Télécharger le fichier
hal-00653671 , version 1 (20-12-2011)
hal-00653671 , version 2 (03-05-2013)
Nicolas Forcadel, Zhiping Rao, Hasnaa Zidani. State-constrained Optimal Control Problems of Impulsive Differential Equations. Applied Mathematics and Optimization, 2013, 68, pp.1--19. ⟨10.1007/s00245-013-9193-5⟩. ⟨hal-00653671v2⟩
539 Consultations
480 Téléchargements
