Reports
Reconfiguration with physical constraints in WDM networks
Sonia Belhareth 1 David Coudert 1 Dorian Mazauric 1 Nicolas Nisse 1 Issam Tahiri 1
1 MASCOTTE - Algorithms, simulation, combinatorics and optimization for telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : In a WDM network, setting up a new wavelength in a fiber requires recalibrating the other wavelengths passing through this fiber. This induces a cost (e.g., time, energy, degradation of QoS) that depends nonlinearly on the number of wavelengths using the fiber. When a set of connection requests must change their optical paths in the network (e.g., during a maintenance operation on a link in the network), the order in which requests are switched affects the total cost of the operation. That is, the reconfiguration of the routing in a WDM network has some cost due to physical layer impairments. We initiate the study of the corresponding optimization problem by modeling the cost of switching a request as a non-linear function depending on the load of the links used by the new lightpath. We prove that determining the optimal rerouting order is NP-complete for a $2$-nodes network. We then give general lower and upper bounds on the minimum cost and we identify classes of instances where the problem can be solved in polynomial time. Finally, we design heuristics for this problem and we analyze and compare them by simulations.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-00654111
Contributor : Nicolas Nisse Connect in order to contact the contributor
Submitted on : Tuesday, December 20, 2011 - 8:26:46 PM
Last modification on : Saturday, June 25, 2022 - 11:07:01 PM
Long-term archiving on: : Monday, December 5, 2016 - 9:23:13 AM
File
RR-7850.pdf
Identifiers
  • HAL Id : hal-00654111, version 1
Collections
Citation
Sonia Belhareth, David Coudert, Dorian Mazauric, Nicolas Nisse, Issam Tahiri. Reconfiguration with physical constraints in WDM networks. [Research Report] RR-7850, INRIA. 2011. ⟨hal-00654111⟩
Share
Metrics
Record views
346
Files downloads
188
